Error????
I keep getting the error message - Error String post processor:System.ComponitModel.Win32Exception (0x0004005): The system cannot find the file specified at System.Diagnostics.Process.(StartInfoStartInfo) at Repetier Host.SlicerPanel.postprocess(String File) I could use all the help I can get to get my new printer working. I am new to this. I have a Tevo Tarantula.
So all you need to go is go through our config tool and compare values with the configuration from your vendors firmware to select the right values. Then check everything from endstops over movements to reading and setting temperatures. Always have a look at the log in your host software and remember that many values are in eeprom and do not update by uploading firmware. Just change them in firmware editor.
https://tevo3dprinterstore.com/pages/tevo-tarantula-firmware
It has the link:
https://www.dropbox.com/sh/ndykfl1wkw8enpj/AACTlV5qC9dpaJA1PYYLACeha?dl=0
for the Tevo Tarantula firmware which is Repetier 0.92, your screenshot shows Marlin firmware. Where did that come from?
If you extract the .rar file you can use the configuration.h that is in it to update the on-line configuration tool. Just print out the configuration.h and enter the parameters. According to the configuration tool page you cannot upload that older one, you should enter the numbers manually.
I am NOT saying there is anything wrong with the newer versions, not at all.
IP: 10.0.0.18
Port: 3344
woudl be how you split theurl to ip/port.
