strange behaviour - Autolevel not working
Hello everyone,
I ran into issues while setting up autoleveling on my P802 printer.
I set up a z-max endstop and home to z-max with G28, this is working fine. My z-max endstop is hooked up to the z-min-pin of my Melzi 2.0 Board and wired in parallel with the Z-Probe sensor.
When I send the G32 S2 command, the extruder starts going towards z-min and goes to the first probing position. As soon as the z-pobe-sensor triggers, I get an error message in Repetier Host, telling me
"Error: z-probe did not untrigger on repetitive measurement - maybe you need to increase distance!
Error:Probing had returned errors - autoleveling canceled."
The display shows "idle" and, depending on other settings, either the x-axis or the x- and z- axis move towards their endstops very slowly until they run into them.
I tried increasing the Z_PROBE_SWITCHING_DISTANCE, but this does not help since the z-axis does not move up at all.
I also tried M500 and changing the eeprom_mode, but this also does not help.
I searched the Forum and googled every keyword i could imagine but found nothing that helped.
I appreciate any tips ans support, I'm out of ideas. Thank you for your Time!
Jagi
#define Z_PROBE_Z_OFFSET 0
#define UI_BED_COATING 1
#define FEATURE_Z_PROBE 1
#define Z_PROBE_PULLUP 0
#define Z_PROBE_ON_HIGH 0
#define Z_PROBE_X_OFFSET -30
#define Z_PROBE_Y_OFFSET 65
#define Z_PROBE_SPEED 2
#define Z_PROBE_XY_SPEED 100
#define Z_PROBE_SWITCHING_DISTANCE 5
#define Z_PROBE_REPETITIONS 3
#define Z_PROBE_HEIGHT 3
#define FEATURE_AUTOLEVEL 1
#define Z_PROBE_X1 70
#define Z_PROBE_Y1 70
#define Z_PROBE_X2 250
#define Z_PROBE_Y2 70
#define Z_PROBE_X3 70
#define Z_PROBE_Y3 250
#define BED_LEVELING_METHOD 1
#define BED_LEVELING_GRID_SIZE 4
#define BED_MOTOR_1_X 0
#define BED_MOTOR_1_Y 0
#define BED_MOTOR_2_X 200
#define BED_MOTOR_2_Y 0
#define BED_MOTOR_3_X 100
#define BED_MOTOR_3_Y 200
#define FEATURE_AXISCOMP 0
#define AXISCOMP_TANXY 0
#define AXISCOMP_TANYZ 0
#define AXISCOMP_TANXZ 0
Jagi
Why cant you connect the Z max endstop to the Z max input pin and leave the Z min probe on the Z min pin
Thanks for your answer, if I have time tonight, I might just try the different wiring.
If you tell firmware to move back after homing a axis so that the axis untriggers, you can use the same pin for x and y endstop. That would be no problem.
Thanks a lot!
Why does it ignore y_max_length and why does it move anyway?
If you need my config.h please let me know, I am currently not at home but I can upload it later.
You can tell firmware to use the probe as the Z min endstop, thus only needing 3 enstop pins, X Y probe.
Thank you very much
