M999 not resetting temp sensor issues as expected
I have a printer with a detachable heated print bed. It is connected via electrical spring connectors. When detaching the print bed from its magnetic fixture points and so disconnecting it from my RADDS+DUE electronics I get the expected "Error:Printer set into dry run mode until restart!" from the Repetier Firmware v0.92.9
After reattaching the print bed, I like to continue printing and therefore enter the M999 command in Repetier-Host. As far as the source code indicates temp sensor errors are reset too. Unfortunately when trying to heat the print bed or the extruder I still get the message "Error:Printer set into dry run mode until restart!". I really have to disconnect and reconnect in Repetier-Host.
Here is a corresponding log:
Maybe it has something to do with the "Other:: temp sensor defect, pwmIndex: 2, sensor pin: 2" and "Other:: working, pwmIndex: 7, sensor pin: 4". I don't have sensors there nor have I configured them in Configuration.h. I only use T0 (TEMP_0_PIN) for my hotend, T1 (TEMP_2_PIN) for the thermo coupled fan and T4 (TEMP_1_PIN) for the heated bed.
14:20:07.114 : DebugLevel:8 <-- here I detached the heated print bed
14:20:07.118 : Other:: working, pwmIndex: 0, sensor pin: 0
14:20:07.122 : Other:: working, pwmIndex: 1, sensor pin: 1
14:20:07.126 : Other:: temp sensor defect, pwmIndex: 2, sensor pin: 2
14:20:07.134 : heated bed: temp sensor defect marked defect, pwmIndex: 3, sensor pin: 3
14:20:07.138 : Other:: working, pwmIndex: 7, sensor pin: 4
14:20:07.143 : Error:Printer set into dry run mode until restart!
14:20:07.146 : Disabling all heaters due to detected sensor defect.
14:20:07.146 : DebugLevel:8
14:25:09.212 : info:Continue from fatal state <-- here I reattached the print bed and fired the M999 command
14:25:18.576 : Other:: working, pwmIndex: 0, sensor pin: 0 <-- here I tried heating the extruder
14:25:18.580 : Other:: working, pwmIndex: 1, sensor pin: 1
14:25:18.588 : Other:: temp sensor defect, pwmIndex: 2, sensor pin: 2
14:25:18.592 : heated bed: working, pwmIndex: 3, sensor pin: 3
14:25:18.596 : Other:: working, pwmIndex: 7, sensor pin: 4
14:25:18.600 : Error:Printer set into dry run mode until restart!
In the screenshot you can see that temperature graph shows the working temp sensor after reattachment.
