Dual x axis - homing problem
Hey
I'm in the process upgrading an old Orcabot XXL, which runs with dual x axis, to Repetier firmware (1.0.0dev).
Unfortunately I'm having some problems with the homing. When I home the x axis, carriage 1 homes just fine to Xmin. However, for some reason carriage 2 also homes to Xmin and not to Xmax how it is supposed to do. Also, if I manually activate the endstop on Xmax nothing happens, however if I activate the Xmin endstop carriage 2 thinks its properly homed.
So it seems like for some reason the firmware tries to home both carriages to the min endstop.
  • Here my configuration for my Orcabot - not sure about the model number. It's one with Arduino Due inside. It is working so it should show the correct setting. Important is that exteruder 1/2 x Offset is distance from the theoretical 0 coordinate on your bed and not distance to each other like for other systems.
        MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
        along with Repetier-Firmware.  If not, see <http://www.gnu.org/licenses/>.
    #ifndef CONFIGURATION_H
    #define CONFIGURATION_H
       This file is optimized for version 1.0.0dev
       as you expect.
    #define NUM_EXTRUDER 2
    #define MOTHERBOARD 402
    #define RFSERIAL Serial
    #include "pins.h"
    #undef FAN_BOARD_PIN
    #define FAN_BOARD_PIN -1
    #define BOARD_FAN_SPEED 255
    #define BOARD_FAN_MIN_SPEED 0
    #define FAN_THERMO_PIN -1
    #undef X_MAX_PIN
    #define X_MAX_PIN ORIG_X_MIN_PIN
    //#define EXTERNALSERIAL  use Arduino serial library instead of build in. Requires more ram, has only 63 byte input buffer.
    //#define COMPAT_PRE1
    #define BLUETOOTH_SERIAL  -1
    #define BLUETOOTH_BAUD  115200
    #define MIXING_EXTRUDER 0
    #define DRIVE_SYSTEM 0
    #define XAXIS_STEPS_PER_MM 512
    #define YAXIS_STEPS_PER_MM 519
    #define ZAXIS_STEPS_PER_MM 23569
    #define PDM_FOR_EXTRUDER 0
    #define PDM_FOR_COOLER 0
    #define DECOUPLING_TEST_MAX_HOLD_VARIANCE 30
    #define RETRACT_ON_PAUSE 2
    #define PAUSE_END_COMMANDS ""
    #define EXT0_X_OFFSET -22784
    #define EXT0_Y_OFFSET 0
    #define EXT0_Z_OFFSET 0
    #define EXT0_STEPS_PER_MM 2230
    #define EXT0_TEMPSENSOR_TYPE 13
    #define EXT0_INVERSE 0
    #define EXT0_ENABLE_ON 1
    #define EXT0_MIRROR_STEPPER 0
    #define EXT0_INVERSE2 0
    #define EXT0_MAX_FEEDRATE 45
    #define EXT0_MAX_ACCELERATION 3000
    #define EXT0_HEAT_MANAGER 1
    #define EXT0_PREHEAT_TEMP 190
    #define EXT0_WATCHPERIOD 1
    #define EXT0_PID_PGAIN_OR_DEAD_TIME 18.3
    #define EXT0_PID_I 2.13
    #define EXT0_PID_D 39
    #define EXT0_PID_MAX 255
    #define EXT0_ADVANCE_K 0
    #define EXT0_ADVANCE_L 10
    #define EXT0_SELECT_COMMANDS "G92 E0\nG1 E10 F300\nG1 E8 F1800\nG92 E0\nM117 Extruder 1\nG4 P1000"
    #define EXT0_DESELECT_COMMANDS "G92 E0\nG1 E-2 F1800\nG92 E0"
    #define EXT0_EXTRUDER_COOLER_PIN HEATER_3_PIN
    #define EXT0_DECOUPLE_TEST_PERIOD 30000
    #define EXT0_JAM_PIN -1
    #define EXT0_JAM_PULLUP 0
    #define EXT1_X_OFFSET 207206
    #define EXT1_Y_OFFSET 0
    #define EXT1_Z_OFFSET 0
    #define EXT1_STEPS_PER_MM 2230
    #define EXT1_TEMPSENSOR_TYPE 13
    #define EXT1_INVERSE 0
    #define EXT1_ENABLE_ON 1
    #define EXT1_MIRROR_STEPPER 0
    #define EXT1_INVERSE2 0
    #define EXT1_MAX_FEEDRATE 45
    #define EXT1_MAX_ACCELERATION 3000
    #define EXT1_HEAT_MANAGER 1
    #define EXT1_PREHEAT_TEMP 190
    #define EXT1_WATCHPERIOD 1
    #define EXT1_PID_PGAIN_OR_DEAD_TIME 18.3
    #define EXT1_PID_I 2.13
    #define EXT1_PID_D 39
    #define EXT1_PID_MAX 255
    #define EXT1_ADVANCE_K 0
    #define EXT1_ADVANCE_L 10
    #define EXT1_SELECT_COMMANDS "G92 E0\nG1 E10 F300\nG1 E8 F1800\nG92 E0\nM117 Extruder 2\nG4 P1000"
    #define EXT1_DESELECT_COMMANDS "G92 E0\nG1 E-2 F1800\nG92 E0"
    #define EXT1_EXTRUDER_COOLER_PIN HEATER_3_PIN
    #define EXT1_DECOUPLE_TEST_PERIOD 30000
    #define EXT1_JAM_PIN -1
    #define EXT1_JAM_PULLUP 0
    #define FEATURE_RETRACTION 1
    #define AUTORETRACT_ENABLED 0
    #define RETRACTION_LENGTH 3
    #define RETRACTION_SPEED 40
    #define RETRACTION_Z_LIFT 0.5
    #define FILAMENTCHANGE_Z_ADD  2
    #define FILAMENTCHANGE_SHORTRETRACT 1
    #define FILAMENTCHANGE_LONGRETRACT 10
    #define JAM_METHOD 1
    #define JAM_STEPS 220
    #define JAM_SLOWDOWN_TO 70
    #define JAM_ERROR_STEPS 500
    #define JAM_MIN_STEPS 10
    #define JAM_ACTION 1
    #define PID_CONTROL_RANGE 20
    #define SKIP_M109_IF_WITHIN 2
    #define SCALE_PID_TO_MAX 0
    #define TEMP_HYSTERESIS 0
    #define EXTRUDE_MAXLENGTH 160
    #define GENERIC_THERM_VREF 5
    #define HEATER_PWM_SPEED 0
    #define HAVE_HEATED_BED 1
    #define SKIP_M190_IF_WITHIN 3
    #define HEATED_BED_SENSOR_TYPE 13
    #define HEATED_BED_PID_PGAIN_OR_DEAD_TIME   131.1
    #define HEATED_BED_PID_IGAIN   3.76
    #define HEATED_BED_PID_DGAIN 1143.1
    #define MIN_EXTRUDER_TEMP 150
    #define MAXTEMP 285
    #define MAX_DEFECT_TEMPERATURE 350
    // ##                             Laser configuration                                      ##
    automatically disabled.
    #define SUPPORT_LASER 0
    #define LASER_PIN -1
    #define LASER_ON_HIGH 1
    #define LASER_WARMUP_TIME 0
    // ##                              CNC configuration                                       ##
    #define SUPPORT_CNC 0
    #define CNC_WAIT_ON_DISABLE 0
    #define CNC_ENABLE_PIN -1
    #define CNC_ENABLE_WITH 1
    #define CNC_DIRECTION_PIN -1
    #define CNC_DIRECTION_CW 1
    #define DOOR_PIN -1
    #define DOOR_PULLUP 1
    #define DOOR_INVERTING 0
    #define ENDSTOP_X_BACK_MOVE 5
    #define ENDSTOP_Y_BACK_MOVE 5
    #define ENDSTOP_Z_BACK_MOVE 2
    #define ENDSTOP_Y_BACK_ON_HOME 0
    #define MOVE_X_WHEN_HOMED 0
    #define MOVE_Y_WHEN_HOMED 0
    #define MOVE_Z_WHEN_HOMED 0
    #define X_ENABLE_ON 1
    #define Y_ENABLE_ON 1
    #define Z_ENABLE_ON 1
    #define DISABLE_X 0
    #define DISABLE_Y 0
    #define DISABLE_Z 0
    #define DISABLE_E 0
    #define INVERT_X_DIR 0
    #define INVERT_Y_DIR 0
    #define INVERT_Z_DIR 1
    #define X_HOME_DIR -1
    #define Y_HOME_DIR -1
    #define Z_HOME_DIR -1
    #define X_MAX_LENGTH 356
    #define Y_MAX_LENGTH 274
    #define Z_MAX_LENGTH 230
    #define X_MIN_POS 0
    #define Y_MIN_POS 0
    #define Z_MIN_POS 0
    #define Z2_MINMAX_PIN -1
    #define DISTORTION_PERMANENT 0
    #define DISTORTION_XMIN 10
    #define DISTORTION_YMIN 10
    #define DISTORTION_XMAX 190
    #define DISTORTION_YMAX 190
    // ##                           Movement settings                                          ##
    #define BABYSTEP_MULTIPLICATOR 200
    #define EXACT_DELTA_MOVES 1
    // Delta settings
    #define DELTA_HOME_ON_POWER 0
    #define MAX_INACTIVE_TIME 0L
    #define MAX_FEEDRATE_X 400
    #define MAX_FEEDRATE_Y 400
    #define MAX_FEEDRATE_Z 10
    #define HOMING_FEEDRATE_X 100
    #define HOMING_FEEDRATE_Y 100
    #define HOMING_FEEDRATE_Z 10
    #define HOMING_ORDER HOME_ORDER_YZX
    #define ZHOME_PRE_RAISE 2
    #define ZHOME_HEAT_ALL 1
    #define ZHOME_HEAT_HEIGHT 20
    #define ZHOME_X_POS 120
    #define ZHOME_Y_POS 120
    #define X_BACKLASH 0
    #define Y_BACKLASH 0
    #define Z_BACKLASH 0
    #define RAMP_ACCELERATION 1
    #define STEPPER_HIGH_DELAY 1
    #define DIRECTION_DELAY 0
    #define ALLOW_QUADSTEPPING 1
    #define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_X 1300
    #define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_Y 300
    #define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_X 3000
    #define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_Y 300
    #define MAX_JERK 5
    #define MAX_ZJERK 0.5
    #define MOVE_CACHE_LOW 10
    #define EXTRUDER_SWITCH_XY_SPEED 300
    #define DUAL_X_AXIS 1
    #define DUAL_X_RESOLUTION 1
    #define X2AXIS_STEPS_PER_MM 400
    #define X2_STEP_PIN   ORIG_E2_STEP_PIN
    #define X2_DIR_PIN    ORIG_E2_DIR_PIN
    #define X2_ENABLE_PIN ORIG_E2_ENABLE_PIN
    #define Y2_STEP_PIN   ORIG_E1_STEP_PIN
    #define Y2_DIR_PIN    ORIG_E1_DIR_PIN
    #define Z2_STEP_PIN   ORIG_E1_STEP_PIN
    #define Z2_DIR_PIN    ORIG_E1_DIR_PIN
    #define Z3_STEP_PIN   ORIG_E2_STEP_PIN
    #define Z3_DIR_PIN    ORIG_E2_DIR_PIN
    #define Z4_STEP_PIN   ORIG_E3_STEP_PIN
    #define Z4_DIR_PIN    ORIG_E3_DIR_PIN
    #define FEATURE_DITTO_PRINTING 1
    #define USE_ADVANCE 1
    #define BAUDRATE 115200
    #define POWER_INVERTING 0
    #define KILL_METHOD 1
    #define ACK_WITH_LINENUMBER 1
    #define ECHO_ON_EXECUTE 1
    #define EEPROM_MODE 1
    #undef PS_ON_PIN
    #define PS_ON_PIN -1
    #define JSON_OUTPUT 0
    /* ======== Servos =======
    Control the servos with
    M340 P<servoId> S<pulseInUS>   / ServoID = 0..3  pulseInUs = 500..2500
    #define FEATURE_SERVO 0
    #define SERVO0_PIN 11
    #define SERVO1_PIN -1
    #define SERVO2_PIN -1
    #define SERVO3_PIN -1
    #define SERVO0_NEUTRAL_POS  -1
    #define SERVO1_NEUTRAL_POS  -1
    #define SERVO2_NEUTRAL_POS  -1
    #define SERVO3_NEUTRAL_POS  -1
    #define UI_SERVO_CONTROL 0
    #define FAN_KICKSTART_TIME  200
            #define FEATURE_WATCHDOG 1
    #define Z_PROBE_Z_OFFSET 0
    #define UI_BED_COATING 0
    #define FEATURE_Z_PROBE 0
    #define EXTRUDER_IS_Z_PROBE 0
    #define Z_PROBE_PULLUP 1
    #define Z_PROBE_ON_HIGH 0
    #define Z_PROBE_X_OFFSET 30
    #define Z_PROBE_Y_OFFSET 20
    #define Z_PROBE_SPEED 10
    #define Z_PROBE_XY_SPEED 250
    #define Z_PROBE_REPETITIONS 1
    #define Z_PROBE_HEIGHT 0
    #define FEATURE_AUTOLEVEL 0
    #define Z_PROBE_X1 20
    #define Z_PROBE_Y1 20
    #define Z_PROBE_X2 160
    #define Z_PROBE_Y2 20
    #define Z_PROBE_X3 20
    #define Z_PROBE_Y3 160
    #define BED_LEVELING_METHOD 0
    #define BED_MOTOR_1_X 0
    #define BED_MOTOR_1_Y 0
    #define BED_MOTOR_2_X 200
    #define BED_MOTOR_2_Y 0
    #define BED_MOTOR_3_X 100
    #define BED_MOTOR_3_Y 200
    #define FEATURE_AXISCOMP 0
    #define AXISCOMP_TANXY 0
    #define AXISCOMP_TANYZ 0
    #define AXISCOMP_TANXZ 0
    #ifndef SDSUPPORT  // Some boards have sd support on board. These define the values already in pins.h
    #define SDSUPPORT 1
    #undef SDCARDDETECT
    #define SDCARDDETECTINVERTED 1
    #define SD_RUN_ON_STOP ""
    #define SD_STOP_HEATER_AND_MOTORS_ON_STOP 0
    #define ARC_SUPPORT 1
    #define FEATURE_FAN_CONTROL 1
    #define FEATURE_FAN2_CONTROL 1
    #define FEATURE_CONTROLLER 25
    #define ADC_KEYPAD_PIN -1
    #define LANGUAGE_EN_ACTIVE 1
    #define LANGUAGE_DE_ACTIVE 1
    #define LANGUAGE_NL_ACTIVE 1
    #define LANGUAGE_PT_ACTIVE 0
    #define LANGUAGE_IT_ACTIVE 0
    #define LANGUAGE_ES_ACTIVE 0
    #define LANGUAGE_FI_ACTIVE 0
    #define LANGUAGE_SE_ACTIVE 0
    #define LANGUAGE_FR_ACTIVE 0
    #define LANGUAGE_CZ_ACTIVE 0
    #define LANGUAGE_PL_ACTIVE 0
    #define LANGUAGE_TR_ACTIVE 0
    #define UI_PRINTER_NAME "Prodim XXL Pro"
    #define UI_PRINTER_COMPANY "V1.0.9"
    #define FEATURE_UI_KEYS 0
    #define UI_ENCODER_SPEED 1
    #define UI_REVERSE_ENCODER 0
    #define UI_KEY_BOUNCETIME 10
    #define UI_KEY_MIN_REPEAT 50
    #define FEATURE_BEEPER 0
    #define CASE_LIGHTS_PIN -1
    #define UI_HEAD "E:%ec/%Ec\002 B:%eb/%Eb\002"
    #define UI_SET_MIN_HEATED_BED_TEMP  40
    #define UI_SET_MIN_EXTRUDER_TEMP   170
    #define UI_SET_MAX_EXTRUDER_TEMP   285
    #define NUM_MOTOR_DRIVERS 0
    // Firmware als basis V1.0.7
    // LAZY_DUAL_X_AXIS 0  >  1 in Repetier.h
    #define LAZY_DUAL_X_AXIS 1
    // Overstap naar Groot scherm > Nu Support voor groot LCD Zie voor veranderingen tabblad LCD 128x64 V1.0.0
    //  RADDS LCD DISPLAY 4x20 naar sparkLCD + adapter on RADDS LCD PORT  + de veranderingen in de tabblad!
    // #define SDCARDDETECTINVERTED van 0 naar 1
    // Logo veranderd naar Prodim in Logo.h
    // #define ENDSTOP_Y_BACK_ON_HOME 10 > 0   (voor groter print bereik in y-as)
    // BED Temperature sensor van 100K EPcos..   naar    PT100 E3D/Ultimaker  (ivm PT100 board ondersteuning)
    // Extr1 Temperature sensor van 100K EPcos..   naar    PT100 E3D/Ultimaker  (ivm PT100 board ondersteuning)
    // Extr2 Temperature sensor van 100K EPcos..   naar    PT100 E3D/Ultimaker (ivm PT100 board ondersteuning)
    // Exotische talen uitgechakeld nu aleen Engels, Duits en Nederlands Beschikbaar.
    // UI_PRINTER_COMPANY Versie nummer V1.0.8 er in gezet.
        "editMode": 2,
        "processor": 1,
        "baudrate": 115200,
        "bluetoothSerial": -1,
        "bluetoothBaudrate": 115200,
        "xStepsPerMM": 512,
        "yStepsPerMM": 519,
        "zStepsPerMM": 23569,
        "xInvert": "0",
        "xInvertEnable": "1",
        "eepromMode": 1,
        "yInvert": "0",
        "yInvertEnable": "1",
        "zInvert": "1",
        "zInvertEnable": "1",
        "extruder": [
                "id": 0,
                "heatManager": 1,
                "pidDriveMin": 40,
                "pidDriveMax": 230,
                "pidMax": 255,
                "sensorType": 13,
                "sensorPin": "TEMP_0_PIN",
                "heaterPin": "HEATER_0_PIN",
                "maxFeedrate": 45,
                "startFeedrate": 20,
                "invert": "0",
                "invertEnable": "1",
                "acceleration": 3000,
                "watchPeriod": 1,
                "pidP": 18.3,
                "pidI": 2.13,
                "pidD": 39,
                "advanceK": 0,
                "advanceL": 10,
                "waitRetractTemp": 150,
                "waitRetractUnits": 0,
                "waitRetract": 0,
                "stepsPerMM": 2230,
                "coolerPin": "HEATER_3_PIN",
                "coolerSpeed": 255,
                "selectCommands": "G92 E0\\nG1 E10 F300\\nG1 E8 F1800\\nG92 E0\\nM117 Extruder 1\\nG4 P1000",
                "deselectCommands": "G92 E0\\nG1 E-2 F1800\\nG92 E0",
                "xOffset": -44.5,
                "yOffset": 0,
                "zOffset": 0,
                "xOffsetSteps": -22784,
                "yOffsetSteps": 0,
                "zOffsetSteps": 0,
                "stepper": {
                    "name": "Extruder 0",
                    "step": "ORIG_E0_STEP_PIN",
                    "dir": "ORIG_E0_DIR_PIN",
                "advanceBacklashSteps": 0,
                "decoupleTestPeriod": 30,
                "jamPin": -1,
                "jamPullup": "0",
                "mirror": "0",
                "invert2": "0",
                "stepper2": {
                "preheat": 190
                "id": 1,
                "heatManager": 1,
                "pidDriveMin": 40,
                "pidDriveMax": 230,
                "pidMax": 255,
                "sensorType": 13,
                "sensorPin": "TEMP_2_PIN",
                "heaterPin": "HEATER_2_PIN",
                "maxFeedrate": 45,
                "invert": "0",
                "watchPeriod": 1,
                "pidP": 18.3,
                "pidI": 2.13,
                "pidD": 39,
                "advanceK": 0,
                "advanceL": 10,
                "waitRetract": 0,
                "stepsPerMM": 2230,
                "coolerSpeed": 255,
                "selectCommands": "G92 E0\\nG1 E10 F300\\nG1 E8 F1800\\nG92 E0\\nM117 Extruder 2\\nG4 P1000",
                "xOffset": 404.7,
                "yOffset": 0,
                "zOffset": 0,
                "xOffsetSteps": 207206,
                "yOffsetSteps": 0,
                "zOffsetSteps": 0,
                "stepper": {
                    "name": "Extruder 1",
                    "step": "ORIG_E1_STEP_PIN",
                    "dir": "ORIG_E1_DIR_PIN",
                "jamPin": -1,
                "jamPullup": "0",
                "mirror": "0",
                "invert2": "0",
                "stepper2": {
                "preheat": 190
        "uiLanguage": 0,
        "uiController": 0,
        "xMinEndstop": 2,
        "yMinEndstop": 2,
        "zMinEndstop": 2,
        "xMaxEndstop": 2,
        "yMaxEndstop": 0,
        "zMaxEndstop": 0,
        "motherboard": 402,
        "driveSystem": 0,
        "xMaxSpeed": 400,
        "xHomingSpeed": 100,
        "xTravelAcceleration": 3000,
        "xPrintAcceleration": 1300,
        "yMaxSpeed": 400,
        "yHomingSpeed": 100,
        "yTravelAcceleration": 300,
        "yPrintAcceleration": 300,
        "zMaxSpeed": 10,
        "zHomingSpeed": 10,
        "zTravelAcceleration": 100,
        "zPrintAcceleration": 100,
        "xMotor": {
            "name": "X motor",
            "step": "ORIG_X_STEP_PIN",
            "dir": "ORIG_X_DIR_PIN",
            "enable": "ORIG_X_ENABLE_PIN"
        "yMotor": {
            "name": "Y motor",
            "step": "ORIG_Y_STEP_PIN",
            "dir": "ORIG_Y_DIR_PIN",
            "enable": "ORIG_Y_ENABLE_PIN"
        "zMotor": {
            "name": "Z motor",
            "step": "ORIG_Z_STEP_PIN",
            "dir": "ORIG_Z_DIR_PIN",
            "enable": "ORIG_Z_ENABLE_PIN"
        "enableBacklash": "0",
        "backlashX": 0,
        "backlashY": 0,
        "backlashZ": 0,
        "stepperInactiveTime": 360,
        "maxInactiveTime": 0,
        "xMinPos": 0,
        "yMinPos": 0,
        "zMinPos": 0,
        "xLength": 356,
        "yLength": 274,
        "zLength": 230,
        "alwaysCheckEndstops": "0",
        "disableX": "0",
        "disableY": "0",
        "disableZ": "0",
        "disableE": "0",
        "xHomeDir": "-1",
        "yHomeDir": "-1",
        "zHomeDir": "-1",
        "xEndstopBack": 1,
        "yEndstopBack": 0,
        "zEndstopBack": 0,
        "deltaDiagonalRod": 445,
        "deltaAlphaA": 210,
        "deltaAlphaB": 330,
        "deltaAlphaC": 90,
        "deltaDiagonalCorrA": 0,
        "deltaDiagonalCorrB": 0,
        "deltaDiagonalCorrC": 0,
        "deltaMaxRadius": 150,
        "deltaRadiusCorrA": 0,
        "deltaRadiusCorrB": 0,
        "deltaRadiusCorrC": 0,
        "deltaXOffsetSteps": 0,
        "deltaYOffsetSteps": 0,
        "deltaZOffsetSteps": 0,
        "deltaSegmentsPerLine": 24,
        "stepperHighDelay": 1,
        "directionDelay": 0,
        "stepDoublerFrequency": 80000,
        "allowQuadstepping": "1",
        "doubleStepDelay": 0,
        "maxJerk": 5,
        "maxZJerk": 0.5,
        "moveCacheSize": 16,
        "moveCacheLow": 10,
        "lowTicksPerMove": 250000,
        "enablePowerOnStartup": "1",
        "echoOnExecute": "1",
        "sendWaits": "1",
        "ackWithLineNumber": "1",
        "killMethod": 1,
        "useAdvance": "1",
        "useQuadraticAdvance": "0",
        "powerInverting": 0,
        "mirrorX": "0",
        "mirrorXMotor": {
            "name": "Extruder 2",
            "step": "ORIG_E2_STEP_PIN",
            "dir": "ORIG_E2_DIR_PIN",
        "mirrorY": 0,
        "mirrorYMotor": {
        "mirrorZ": "0",
        "mirrorZMotor": {
        "mirrorZ3": "0",
        "mirrorZ3Motor": {
        "mirrorZ4": "0",
        "mirrorZ4Motor": {
            "name": "Extruder 3",
            "step": "ORIG_E3_STEP_PIN",
            "dir": "ORIG_E3_DIR_PIN",
        "dittoPrinting": "1",
        "featureServos": "0",
        "servo0Pin": 11,
        "servo1Pin": -1,
        "servo2Pin": -1,
        "servo3Pin": -1,
        "featureWatchdog": "1",
        "hasHeatedBed": "1",
        "enableZProbing": "0",
        "extrudeMaxLength": 160,
        "homeOrder": "HOME_ORDER_YZX",
        "featureController": 25,
        "uiPrinterName": "Prodim XXL Pro",
        "uiPrinterCompany": "V1.0.9",
        "uiPagesDuration": 4000,
        "uiHeadline": "E:%ec\/%Ec\\002 B:%eb\/%Eb\\002",
        "uiDisablePageswitch": "1",
        "uiAutoReturnAfter": 30000,
        "featureKeys": "0",
        "uiEncoderSpeed": 1,
        "uiReverseEncoder": "0",
        "uiKeyBouncetime": 10,
        "uiKeyFirstRepeat": 500,
        "uiKeyReduceRepeat": 50,
        "uiKeyMinRepeat": 50,
        "featureBeeper": "0",
        "uiMinHeatedBed": 40,
        "uiMaxHeatedBed": 120,
        "uiMinEtxruderTemp": 170,
        "uiMaxExtruderTemp": 285,
        "uiExtruderFeedrate": 2,
        "maxBedTemperature": 120,
        "bedSensorType": 13,
        "bedSensorPin": "TEMP_1_PIN",
        "bedHeatManager": 1,
        "bedPreheat": 55,
        "bedUpdateInterval": 5000,
        "bedPidDriveMin": 80,
        "bedPidDriveMax": 255,
        "bedPidP": 131.1,
        "bedPidI": 3.76,
        "bedPidD": 1143.1,
        "bedPidMax": 255,
        "bedDecoupleTestPeriod": 300,
        "caseLightPin": -1,
        "caseLightDefaultOn": "1",
        "bedSkipIfWithin": 3,
        "gen1T0": 25,
        "gen1R0": 100,
        "gen1Beta": 500,
        "gen1MinTemp": -20,
        "gen1MaxTemp": 300,
        "gen1R1": 4700,
        "gen1R2": 4700,
        "gen2T0": 25,
        "gen2R0": 100000,
        "gen2Beta": 4036,
        "gen2MinTemp": -20,
        "gen2MaxTemp": 300,
        "gen2R1": 0,
        "gen2R2": 4700,
        "gen3T0": 25,
        "gen3R0": 100000,
        "gen3Beta": 4036,
        "gen3MinTemp": -20,
        "gen3MaxTemp": 300,
        "gen3R1": 0,
        "gen3R2": 4700,
        "userTable0": {
            "r1": 4700,
            "r2": 4700,
            "temps": [
                    "t": 0,
                    "r": 100,
                    "adc": 83.5714285714
                    "t": 10,
                    "r": 103.9,
                    "adc": 86.6927136395
                    "t": 20,
                    "r": 107.8,
                    "adc": 89.8040930914
                    "t": 30,
                    "r": 111.7,
                    "adc": 92.9056140066
                    "t": 40,
                    "r": 115.5,
                    "adc": 95.9181707564
                    "t": 50,
                    "r": 119.4,
                    "adc": 99.000364461
                    "t": 60,
                    "r": 123.2,
                    "adc": 101.994177584
                    "t": 70,
                    "r": 127.1,
                    "adc": 105.057224173
                    "t": 80,
                    "r": 130.9,
                    "adc": 108.032468056
                    "t": 90,
                    "r": 134.7,
                    "adc": 110.998611502
                    "t": 100,
                    "r": 138.5,
                    "adc": 113.955696203
            "numEntries": 11
        "userTable1": {
            "r1": 0,
            "r2": 4700,
            "temps": [],
            "numEntries": 0
        "userTable2": {
            "r1": 0,
            "r2": 4700,
            "temps": [],
            "numEntries": 0
        "tempHysteresis": 0,
        "pidControlRange": 20,
        "skipM109Within": 2,
        "extruderFanCoolTemp": 50,
        "minTemp": 150,
        "maxTemp": 285,
        "minDefectTemp": -10,
        "maxDefectTemp": 350,
        "arcSupport": "1",
        "forceChecksum": "0",
        "sdExtendedDir": "1",
        "featureFanControl": "1",
        "fanPin": "ORIG_FAN_PIN",
        "featureFan2Control": "1",
        "fan2Pin": "ORIG_FAN2_PIN",
        "fanThermoPin": -1,
        "fanThermoMinPWM": 128,
        "fanThermoMaxPWM": 255,
        "fanThermoMinTemp": 45,
        "fanThermoMaxTemp": 60,
        "fanThermoThermistorPin": -1,
        "fanThermoThermistorType": 1,
        "scalePidToMax": 0,
        "zProbeBedDistance": 10,
        "zProbePullup": "1",
        "zProbeOnHigh": "0",
        "zProbeXOffset": 30,
        "zProbeYOffset": 20,
        "zProbeWaitBeforeTest": "0",
        "zProbeSpeed": 10,
        "zProbeXYSpeed": 250,
        "zProbeHeight": 0,
        "zProbeStartScript": "",
        "zProbeFinishedScript": "",
        "featureAutolevel": "0",
        "zProbeX1": 20,
        "zProbeY1": 20,
        "zProbeX2": 160,
        "zProbeY2": 20,
        "zProbeX3": 20,
        "zProbeY3": 160,
        "zProbeSwitchingDistance": 1,
        "zProbeRepetitions": 1,
        "zProbeEveryPoint": "",
        "sdSupport": "1",
        "sdCardDetectPin": "ORIG_SDCARDDETECT",
        "sdCardDetectInverted": "1",
        "uiStartScreenDelay": 1000,
        "xEndstopBackMove": 5,
        "yEndstopBackMove": 5,
        "zEndstopBackMove": 2,
        "xEndstopRetestFactor": 3,
        "yEndstopRetestFactor": 3,
        "zEndstopRetestFactor": 3,
        "xMinPin": "ORIG_X_MIN_PIN",
        "yMinPin": "ORIG_Y_MIN_PIN",
        "zMinPin": "ORIG_Z_MIN_PIN",
        "xMaxPin": "ORIG_X_MIN_PIN",
        "yMaxPin": "ORIG_Y_MAX_PIN",
        "zMaxPin": "ORIG_Z_MAX_PIN",
        "deltaHomeOnPower": "0",
        "fanBoardPin": -1,
        "heaterPWMSpeed": 0,
        "featureBabystepping": "1",
        "babystepMultiplicator": 200,
        "pdmForHeater": "0",
        "pdmForCooler": "0",
        "psOn": -1,
        "mixingExtruder": "0",
        "decouplingTestMaxHoldVariance": 30,
        "featureAxisComp": "0",
        "axisCompTanXY": 0,
        "axisCompTanXZ": 0,
        "axisCompTanYZ": 0,
        "retractOnPause": 2,
        "pauseStartCommands": "",
        "pauseEndCommands": "",
        "distortionCorrection": "0",
        "distortionCorrectionR": 100,
        "distortionPermanent": "0",
        "distortionEndDegrade": 1,
        "distortionXMin": 10,
        "distortionXMax": 190,
        "distortionYMin": 10,
        "distortionYMax": 190,
        "sdRunOnStop": "",
        "sdStopHeaterMotorsOnStop": "0",
        "featureRetraction": "1",
        "autoretractEnabled": "0",
        "retractionLength": 3,
        "retractionLongLength": 13,
        "retractionSpeed": 40,
        "retractionZLift": 0.5,
        "retractionUndoSpeed": 20,
        "filamentChangeXPos": 0,
        "filamentChangeYPos": 0,
        "filamentChangeZAdd": 2,
        "filamentChangeRehome": 1,
        "filamentChangeShortRetract": 1,
        "filamentChangeLongRetract": 10,
        "fanKickstart": 200,
        "servo0StartPos": -1,
        "servo1StartPos": -1,
        "servo2StartPos": -1,
        "servo3StartPos": -1,
        "uiDynamicEncoderSpeed": "1",
        "uiServoControl": 0,
        "killIfSensorDefect": "0",
        "jamSteps": 220,
        "jamSlowdownSteps": 320,
        "jamSlowdownTo": 70,
        "jamErrorSteps": 500,
        "jamMinSteps": 10,
        "jamAction": 1,
        "jamMethod": 1,
        "primaryPort": 1,
        "numMotorDrivers": 0,
        "motorDrivers": [
                "t": "None",
                "s": "",
                "invertEnable": "0",
                "invertDirection": "0",
                "stepsPerMM": 100,
                "speed": 10,
                "dirPin": -1,
                "stepPin": -1,
                "enablePin": -1
                "t": "None",
                "s": "",
                "stepsPerMM": 100,
                "speed": 10,
                "dirPin": -1,
                "stepPin": -1,
                "enablePin": -1
                "t": "None",
                "s": "",
                "stepsPerMM": 100,
                "speed": 10,
                "dirPin": -1,
                "stepPin": -1,
                "enablePin": -1
                "t": "None",
                "s": "",
                "stepsPerMM": 100,
                "speed": 10,
                "dirPin": -1,
                "stepPin": -1,
                "enablePin": -1
                "t": "None",
                "s": "",
                "stepsPerMM": 100,
                "speed": 10,
                "dirPin": -1,
                "stepPin": -1,
                "enablePin": -1
                "t": "None",
                "s": "",
                "stepsPerMM": 100,
                "speed": 10,
                "dirPin": -1,
                "stepPin": -1,
                "enablePin": -1
        "manualConfig": "\/\/ Firmware als basis V1.0.7 \n\/\/ LAZY_DUAL_X_AXIS 0  >  1 in Repetier.h\n#define LAZY_DUAL_X_AXIS 1\n\/\/ Overstap naar Groot scherm > Nu Support voor groot LCD Zie voor veranderingen tabblad LCD 128x64 V1.0.0\n\/\/  RADDS LCD DISPLAY 4x20 naar sparkLCD + adapter on RADDS LCD PORT  + de veranderingen in de tabblad!\n\/\/ #define SDCARDDETECTINVERTED van 0 naar 1\n\/\/ Logo veranderd naar Prodim in Logo.h\n\/\/ #define ENDSTOP_Y_BACK_ON_HOME 10 > 0   (voor groter print bereik in y-as)\n\n\/\/ BED Temperature sensor van 100K EPcos..   naar    PT100 E3D\/Ultimaker  (ivm PT100 board ondersteuning)\n\/\/ Extr1 Temperature sensor van 100K EPcos..   naar    PT100 E3D\/Ultimaker  (ivm PT100 board ondersteuning)\n\/\/ Extr2 Temperature sensor van 100K EPcos..   naar    PT100 E3D\/Ultimaker (ivm PT100 board ondersteuning)\n\n\/\/ Exotische talen uitgechakeld nu aleen Engels, Duits en Nederlands Beschikbaar.\n\/\/ UI_PRINTER_COMPANY Versie nummer V1.0.8 er in gezet.",
        "zHomeMinTemperature": 0,
        "zHomeXPos": 120,
        "zHomeYPos": 120,
        "zHomeHeatHeight": 20,
        "zHomeHeatAll": "1",
        "zProbeZOffsetMode": 0,
        "zProbeZOffset": 0,
        "uiBedCoating": "0",
        "langEN": "1",
        "langDE": "1",
        "langNL": "1",
        "langPT": "0",
        "langIT": "0",
        "langES": "0",
        "langFI": "0",
        "langSE": "0",
        "langFR": "0",
        "langCZ": "0",
        "langPL": "0",
        "langTR": "0",
        "accelerationFactorTop": 100,
        "bendingCorrectionA": 0,
        "bendingCorrectionB": 0,
        "bendingCorrectionC": 0,
        "supportLaser": "0",
        "laserPin": -1,
        "laserOnHigh": "1",
        "laserWarmupTime": 0,
        "defaultPrinterMode": 0,
        "supportCNC": "0",
        "cncWaitOnEnable": 300,
        "cncWaitOnDisable": 0,
        "cncEnablePin": -1,
        "cncEnableWith": "1",
        "cncDirectionPin": -1,
        "cncDirectionCW": "1",
        "startupGCode": "",
        "jsonOutput": "0",
        "bedLevelingMethod": 0,
        "bedCorrectionMethod": 0,
        "bedLevelingGridSize": 5,
        "bedLevelingRepetitions": 5,
