Print button kills existing print in progress!
I was near the end of a four hour print.
I loaded a new stl and sliced it, ready to go after current print finished.
Inadvertantly hit the print button and lost 4 hours of printing when it terminated the existing print without asking!
I think there should be an "Are you sure?" Dialog befor terminating a print.
You should not really do anything heavy like slicing with host while printing. This can easily cause small pauses. If you want to continue, you should consider using repetier-server for printing tasks. That way even closing host would not affect the running print.
so it is a bug that you can press print in the preview screen while it is printing?
