Second extruder 10 degrees to cold
I have the dual version of the Felix V3
The first extruder heats up normal and hits its temp just fine
The second one heats up normal but stops 10 degrees below the set temperature
tried to autotune the PID of the second extruder but with no positive out come
Tried switching the hot ends but the problem remains
It makes no differents if i set it by software or set it using the display
The second extruder heats up to the set tempatur but then starts to jump around.
Going between 230 to 198 in less then a second and back in less then a second.
With a older version of the firmware i have only the problem that the second extruder won't heat up to the set temp.
Just to be sure i connected ext1 to the connectors of ext2 but the problem remains
