Stepper issues with RADDS + DUE + RAPS128 (Cartesian printer)
Decided to upgrade my controller to a DUE with RADDS + RAPS128 drivers.
I've followed the steps in the radds.org site to have Repetier set for this but I can't get the steppers to move correctly.
For the X when moving in one direction it sometimes even moves back in the opposite direction and in long continuous
movements (i.e: homing some small stops can be see at intervals)
For the Y it just pauses and moves and pauses and moves, non-stop... and I end up having to reset the printed. :S
I'd assume this must be some setting that I'm missing.
Anyone care to share their configuration.h so that I use it as base to create mine.
Cheers
That was right after turning on the printer.
But it gets even more weird with the Y axis. That after any movement it keeps moving on it's own.
In there I only made it home the Y axis.
I thought it could be the RAPS128 drivers and swapped them to some DRV8825 I have but it does the same.
So I guess is something with the firmware or the DUE?
But I was hopping to get it working. Prior to deciding to get a RADDS I searched for it and found some details of people that managed to do it.
To be honest I could even ignore the SD card support. I use Repetier server for printing so I never use the SD card.
Oh and by theway. it is EXACTLY the same: X moves and then backs up, and Y moves intermittedly
