Get Endstop Status via Web API
I am wondering if there is any possibility to read the end stop states via the Web API. As the action "send" doesn't return any values "M119" doesn't work....
Best regards
Stefan
Stefan
- Regarding your last sentence: Does it refer to the Web API or also on the module API? If it does refer to the Web API can you please give me an approach example? I already tried to get the information by setting the logLevel to 15
What I tried so far is:
#1:
action = activePrinter
Payload = „printer“:“3DPrinterV2“
#2:
action = sendMoves
#from then I get the moves at least
#3:
action = setLogLevel
Payload = "level":15
#But that unfortunately doesn't sends any more information
Did I get something wrong?
Best regards
Stefan
But it does not send response directly. All following lines will be send as an event!
So for everyone who's interested:
First step send as action "setLoglevel" --> take care of the typo!
with payload: {"printer":"3DPrinterV2","level":4} --> replace "3DPrinterV2" with your printer's slug
Maybe you have to try out different log levels, for the Endstops the right level is 4. For those struggling with the numbers:
1 : Commands
2 : ACK responses like ok, wait, temperature
4 : Other responses
8 : Non maskable messages
You can combine the levels by adding the numbers up, e.g. for all logs it's 1+2+4+8=15
From then you can use the action "send" with payload (in my case): {"cmd":"M119"}
The Web API will answer you with something like that:
Best regards
Stefan
