Get Endstop Status via Web API
I am wondering if there is any possibility to read the end stop states via the Web API. As the action "send" doesn't return any values "M119" doesn't work....
Best regards
Stefan
  • Firmware output has no reference to commands issued so there can be no answer for this. As a module you can subscribe to all firmware answers and check if it is a m119 response and act on it. On the other end you would need to enable logging to get the same data.
  • I am not a 100% sure if I get you right:
    - Creating own modules with the module system API (which requires Pro Version) is possible.
    - Regarding your last sentence: Does it refer to the Web API or also on the module API? If it does refer to the Web API can you please give me an approach example? I already tried to get the information by setting the logLevel to 15
    What I tried so far is:
    #1:
    action = activePrinter
    Payload = „printer“:“3DPrinterV2“
    #2:
    action = sendMoves
    #from then I get the moves at least
    #3:
    action = setLogLevel
    Payload = "level":15
    #But that unfortunately doesn't sends any more information
    Did I get something wrong?
    Best regards
    Stefan
  • Option 3 is qhat you want. Do not forget also to send the printer. There might be a typo in docs if i forgot to fix that. Could also be setLoglevel .
    But it does not send response directly. All following lines will be send as an event!
  • Awesome, thank you very much!
    So for everyone who's interested:
    First step send as action "setLoglevel" --> take care of the typo!
    with payload: {"printer":"3DPrinterV2","level":4} --> replace "3DPrinterV2" with your printer's slug
    Maybe you have to try out different log levels, for the Endstops the right level is 4. For those struggling with the numbers:
    1 : Commands
    2 : ACK responses like ok, wait, temperature
    4 : Other responses
    8 : Non maskable messages
    You can combine the levels by adding the numbers up, e.g. for all logs it's 1+2+4+8=15
    From then you can use the action "send" with payload (in my case): {"cmd":"M119"}
    The Web API will answer you with something like that:
    Best regards
    Stefan
