Automated Printing Issue
Hi all,
I'm new to the product/forum but it seems like the best place
to look for help.
I recently bought a "DOBOT Magician" which has a
function of 3d printing and the manual suggest using Repetier Host.
After following all of the instruction in the manual, I am
able to move the robot manually and even control the flow of the material, unfortunately
when I go about printing a 3d model the g-code is send to the robot, and
Repetier shows the movement but the robot itself is idle
I would appreciate and suggestion that might help me fix the
issue help me create my first hand made model.
In such cases you should at first take a look at the log if it contains any hints, e.g. heating failed and it starts to ignore all following commands would be a typical reason.
I went through the log, It shows no errors, as I mentioned before the commands are being sent line by line without any errors, but the robot itself is idle during those commands
