Raspberry Pi 3 running 0_85_2_v7 - How do I shut off the silly wireless access point
Raspberry Pi 3
0_85_2_v7
32 gig SD
I have 3 different wireless routers this can connect to, on channel 1, 6, or 11. All running WPA2. I moved one to WPA, just in case that was the issue.
I can connect to the Raspberry Pi thru the Wireless access point. I can also connect with a cable connection. I want to turn off the silly wireless access point, and connect to the LAN over wifi. How do I do this?
Even now, while I am connected over LAN cable, the Wireless Access Point is still running. I've typed in the wireless information over and over, and it just will not connect. I expected the Wireless Access Point to turn itself off when it seen the wired connection working. No Such Luck.
There must be a simple check box. All the FAQ's for version 6 mention a simple check box, but my version 7 seems to have no such check box. Thank you for reading, and any advice you may have.
0_85_2_v7
32 gig SD
I did finally get the Wireless Access Point turned off. However, I still can not make the Pi connect to a wifi. I hoped the problem was the Wireless Access Point being turned off. Apparently this was not the case.
Anyone able to get 0.82.2 V7 to connect to a wifi?
It would be nice if this worked from the gui at /#/gsettings/wlan
Maybe something that's being worked on? Good luck.
