Levelling Z table position
Hi guys I have a question. When I home the z table manually, it homes without any problem but when starts printing it homes z table by touching endstop , right after it goes back.As a result there has been 2 or 3 mm gap between nozzle and table.I know it is a basic questıon but I am just a starter.
thanks in advance
thanks in advance
I appreciate it.
Beside this question , My printer is corexy
Do I need to calibrate x y and z motors ?
For sure I calibrated extruder .
My problem is when printing second layer , nozzle is touching to the printing object
I thought it is the calibration issues???
thank you in advance
If you extrude too much you will touch the printed object. Having xy too lof would add more plasic per mm as planned so that might be the reason.
