autolevel
bonjour
j ai une he3d k280 depuis peux,j ai fais beaucoup de modif mais impossible d imprimer // au lit
il y a un default de 2 a 3 /10 je ne trouve pas le probleme si vous pouvez m aider
merci d avance
voici une partie du fichier  configuration.h
#define ENDSTOP_X_MAX_INVERTING true
#define ENDSTOP_Y_MAX_INVERTING true
#define ENDSTOP_Z_MAX_INVERTING true
#define ENDSTOP_X_BACK_MOVE 10 //modif 5----10
#define ENDSTOP_Y_BACK_MOVE 10 //modif 5----10
#define ENDSTOP_Z_BACK_MOVE 10 //modif 5----10
#define ALWAYS_CHECK_ENDSTOPS 0 //modif 1-------0
#define X_ENABLE_ON 0
#define Y_ENABLE_ON 0
#define Z_ENABLE_ON 0
#define DISABLE_X 0
#define DISABLE_Y 0
#define DISABLE_Z 0
#define DISABLE_E 0
#define INVERT_X_DIR 1 //modif 0----1
#define INVERT_Y_DIR 1 //modif 0----1
#define INVERT_Z_DIR 1 //modif 0----1
#define X_HOME_DIR -1
#define Y_HOME_DIR -1
#define Z_HOME_DIR 1
#define X_MAX_LENGTH 280
#define Y_MAX_LENGTH 280
#define Z_MAX_LENGTH 582.75 //modif orig. 600.5
#define X_MIN_POS 0
#define Y_MIN_POS 0
#define Z_MIN_POS 0
#define DISTORTION_XMIN 10
#define DISTORTION_YMIN 10
#define DISTORTION_XMAX 290
#define DISTORTION_YMAX 290
// ##                           Movement settings                                          ##
#define EXACT_DELTA_MOVES 1
// Delta settings
#define DELTA_DIAGONAL_ROD 325 //origine 340mm---326 precision x y
#define DELTA_ALPHA_A 210
#define DELTA_ALPHA_B 330
#define DELTA_ALPHA_C 90
#define END_EFFECTOR_HORIZONTAL_OFFSET 20.8 //modif 0-----20.8
#define DELTA_MAX_RADIUS 140
#define ROD_RADIUS 174 //modif 177------175
#define PRINTER_RADIUS 177
#define DELTA_HOME_ON_POWER 0
#define STEP_COUNTER
#define DELTA_Y_ENDSTOP_OFFSET_STEPS 350 // modif 0----xxx
#define DELTA_Z_ENDSTOP_OFFSET_STEPS 179 // modif 0---xxx
//#define SOFTWARE_LEVELING
#define MAX_INACTIVE_TIME 0L
#define MAX_FEEDRATE_X 300
#define MAX_FEEDRATE_Y 300
#define MAX_FEEDRATE_Z 300
#define HOMING_FEEDRATE_X 40
#define HOMING_FEEDRATE_Y 40
#define HOMING_FEEDRATE_Z 40
#define ZHOME_HEAT_ALL 1
#define ZHOME_HEAT_HEIGHT 20
#define ZHOME_X_POS 999999
#define ZHOME_Y_POS 999999
#define X_BACKLASH 0
#define Y_BACKLASH 0
#define Z_BACKLASH 0
#define RAMP_ACCELERATION 1
#define STEPPER_HIGH_DELAY 0
#define DIRECTION_DELAY 0
#define ALLOW_QUADSTEPPING 1
#define DOUBLE_STEP_DELAY 1 // time in microseconds
#define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_Z 1000
#define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_Z 1000
#define MAX_JERK 20
#define MAX_ZJERK 0.3
#define PRINTLINE_CACHE_SIZE 8 //modif 16----8
#define MOVE_CACHE_LOW 10
#define DUAL_X_AXIS 0
#define X2_STEP_PIN   ORIG_E1_STEP_PIN
#define X2_DIR_PIN    ORIG_E1_DIR_PIN
#define Y2_STEP_PIN   ORIG_E1_STEP_PIN
#define Y2_DIR_PIN    ORIG_E1_DIR_PIN
#define Z2_STEP_PIN   ORIG_E1_STEP_PIN
#define Z2_DIR_PIN    ORIG_E1_DIR_PIN
#define Z3_STEP_PIN   ORIG_E2_STEP_PIN
#define Z3_DIR_PIN    ORIG_E2_DIR_PIN
#define USE_ADVANCE 0
#define BAUDRATE 250000
#define POWER_INVERTING 0
#define KILL_METHOD 1
#define ACK_WITH_LINENUMBER 1
#define ECHO_ON_EXECUTE 1
#define EEPROM_MODE 4
#undef PS_ON_PIN
#define JSON_OUTPUT 0
/* ======== Servos =======
Control the servos with
M340 P<servoId> S<pulseInUS>   / ServoID = 0..3  pulseInUs = 500..2500
#define FEATURE_SERVO 0
#define SERVO0_PIN 11
#define SERVO1_PIN -1
#define SERVO2_PIN -1
#define SERVO3_PIN -1
#define SERVO0_NEUTRAL_POS  0
#define UI_SERVO_CONTROL 0
        #define FEATURE_WATCHDOG 0
#define Z_PROBE_Z_OFFSET 0
#define Z_PROBE_Z_OFFSET_MODE 1 //modif 0---1
#define UI_BED_COATING 1
#define FEATURE_Z_PROBE 1
#define Z_PROBE_BED_DISTANCE 20
#define Z_PROBE_PULLUP 1  //modif 0---->true
#define Z_PROBE_ON_HIGH 1    //modif 0----> 1
#define Z_PROBE_X_OFFSET -13
#define Z_PROBE_Y_OFFSET -5
#define Z_PROBE_WAIT_BEFORE_TEST 0 //modif true pour attente ordre 0 pas d attente
#define Z_PROBE_SPEED 5 //modif 10---->5
#define Z_PROBE_XY_SPEED 150
#define Z_PROBE_SWITCHING_DISTANCE 5 //modif 1---->5
#define Z_PROBE_REPETITIONS 2  //modif 1------>3
#define Z_PROBE_HEIGHT 6.45  //modif 40----  > xxx distance buse lit
#define FEATURE_AUTOLEVEL 1
#define Z_PROBE_X1 -80
#define Z_PROBE_Y1 -50
#define Z_PROBE_X2 80
#define Z_PROBE_Y2 -50
#define Z_PROBE_X3 0
#define Z_PROBE_Y3 80
#define Z_PROBE_X1 -100
#define Z_PROBE_Y1 -60
#define Z_PROBE_X2 90
#define Z_PROBE_Y2 -60
#define Z_PROBE_X3 -100
#define Z_PROBE_Y3 60
#define BED_LEVELING_METHOD 1 //modif 0-----2  //modif 0 pour 3 points ---1 pour une grille
#define BED_LEVELING_GRID_SIZE 3 //modif 5---->3
#define BED_LEVELING_REPETITIONS 3 //modif 5---->3
#define BED_MOTOR_1_X 0
#define BED_MOTOR_1_Y 0
#define BED_MOTOR_2_X 200
#define BED_MOTOR_2_Y 0
#define BED_MOTOR_3_X 100
#define BED_MOTOR_3_Y 200
#define FEATURE_AXISCOMP 0
#define AXISCOMP_TANXY 0
#define AXISCOMP_TANYZ 0
#define AXISCOMP_TANXZ 0
  • help me please :(
  • What's the problem?
  • bonjour
    impossible d'imprimer // au lit il y as un default de 3 a 4/10
    je ne trouve pas la solution
    merci
    Hello
    Can not print // in bed there is a default of 3 to 4/10
    I do not find the solution
    thank you
  • That question makes no sense. What is 3 to 4/10 // ?
  • bonjour
    oui en effet pas de sens
    c est le niveau du lit d un cote la buse touche le lit de l autre a 150mm la buse est 3 a 4/10 au dessus malgré l autolevel
    dans le g code j ai insere m320 s2
    et avant de lancer la machine je fait
    m322
    ensuite
    g32 s2
    Hello
    Yes indeed no sense
    C is the level of the bed of one side the nozzle touches the bed of the other has 150mm the nozzle is 3 to 4/10 to the top despite the autolevel
    In the code j ai insert m320 s2
    And before launching the machine I made
    m322
    then
    G32 s2
  • Forget M322 and M320 completely if you need autolevel. Just do a G32 S2 and it stores data in eeprom and activates autolevel until you say otherwise.
    Check eeprom if bending correction is 0 for all 3 points. Configure autoleveling to do a mesh leveling with 4x4 points. If you have only 3 points one bad measurement can make a huge error. Maximize measured area as max as you can considering that probe offset gets activated which normally reduces reachable area. That should give you best autolevel correction. Store log output of G32 S2 increase it still does not work. It shows what rotation is detected an can show if some points might be measured wrong if you compare close by points.
    Then move slowly from left to right/fron/back and see if z moves along with move. Might be hard to see but touching z axis helps feel the rotation.
    If you have mechanical z probe and cantilevered bed design it might give away at the outside - that is where bending correction is for. Increase it for the point where gap is at maximum with the gap size when z=0 and redo G32. Now bending is added to probe results and should improve the rotation (or make it worse when wrong sign/distance used).
  • bonjour
     j ai un petit probleme
    je voudrais avoir 2 fils differents avec la meme tete , je n arrive pas a faire la modif
    j ai definie 2 extruders mais ca ne marche pas
    pouvez vous me dire ce qu il faut faire
    merci
    ci joint une partie du fichier config
    #define NUM_EXTRUDER 2
    #define MOTHERBOARD 33
    #include "pins.h"
    #undef FAN_BOARD_PIN
    #define FAN_BOARD_PIN -1
    #define BOARD_FAN_SPEED 255
    #define FAN_THERMO_PIN -1
    //#define COMPAT_PRE1
    #define BLUETOOTH_SERIAL  -1
    #define MIXING_EXTRUDER 0
    #define DRIVE_SYSTEM 3
    #define XAXIS_STEPS_PER_MM 80
    #define YAXIS_STEPS_PER_MM 80
    #define ZAXIS_STEPS_PER_MM 80
    #define PDM_FOR_EXTRUDER 0
    #define PDM_FOR_COOLER 0
    #define RETRACT_ON_PAUSE 2
    #define PAUSE_END_COMMANDS ""
    #define EXT0_X_OFFSET 0
    #define EXT0_Y_OFFSET 0
    #define EXT0_Z_OFFSET 0
    #define EXT0_STEPS_PER_MM 100
    #define EXT0_INVERSE 1
    #define EXT0_ENABLE_ON 0
    #define EXT0_MIRROR_STEPPER 0
    #define EXT0_INVERSE2 0
    #define EXT0_MAX_FEEDRATE 150
    #define EXT0_HEAT_MANAGER 1
    #define EXT0_WATCHPERIOD 1
    #define EXT0_PID_I 2
    #define EXT0_PID_D 40
    #define EXT0_PID_MAX 255
    #define EXT0_ADVANCE_K 0
    #define EXT0_ADVANCE_L 0
    #define EXT0_JAM_PIN -1
    #define EXT0_JAM_PULLUP 0
    #define EXT1_X_OFFSET 0
    #define EXT1_Y_OFFSET 0
    #define EXT1_Z_OFFSET 0
    #define EXT1_STEPS_PER_MM 100
    #define EXT1_TEMPSENSOR_TYPE 8
    #define EXT1_TEMPSENSOR_PIN  TEMP_2_PIN  //modif TEMP_2_PIN------TEMP_0_PIN
    #define EXT1_HEATER_PIN 7      //modif EXT1_HEATER_PIN 7 ------EXT1_HEATER_PIN HEATER_0_PIN
    #define EXT1_INVERSE 1
    #define EXT1_ENABLE_ON 0
    #define EXT1_MIRROR_STEPPER 0
    #define EXT1_INVERSE2 0
    #define EXT1_MAX_FEEDRATE 50
    #define EXT1_HEAT_MANAGER 1
    #define EXT1_WATCHPERIOD 1
    #define EXT1_PID_I 2
    #define EXT1_PID_D 40
    #define EXT1_PID_MAX 255
    #define EXT1_ADVANCE_K 0
    #define EXT1_ADVANCE_L 0
    #define EXT1_JAM_PIN -1
    #define EXT1_JAM_PULLUP 0
    #define FEATURE_RETRACTION 1
    #define AUTORETRACT_ENABLED 0
    #define RETRACTION_LENGTH 3
    #define RETRACTION_SPEED 40
    #define RETRACTION_Z_LIFT 0
    #define JAM_STEPS 220
    #define JAM_SLOWDOWN_TO 70
    #define JAM_ERROR_STEPS 500
    #define JAM_MIN_STEPS 10
    #define JAM_ACTION 1
    #define PID_CONTROL_RANGE 10
    #define SKIP_M109_IF_WITHIN 2
    #define SCALE_PID_TO_MAX 1
    #define TEMP_HYSTERESIS 0
    #define EXTRUDE_MAXLENGTH 160
    #define GENERIC_THERM_VREF 5
    #define HEATER_PWM_SPEED 0
    #define HAVE_HEATED_BED 1
    #define SKIP_M190_IF_WITHIN 3
    #define HEATED_BED_SENSOR_TYPE 8
    #define HEATED_BED_HEAT_MANAGER 3
    #define HEATED_BED_PID_PGAIN_OR_DEAD_TIME   196
    #define HEATED_BED_PID_IGAIN   33
    #define MIN_EXTRUDER_TEMP 150
    #define MAXTEMP 275
  • And in a language we understand?
  • je viens vers vous pour un petit coups de main
    je viens d acheter un extruder style cyclope ( 1 extruder pour 2 ou 3 couleurs) mais voila comme d habitude , j ai un souci.
    j ai modifier le firmware de mon imprimante mais lorsque je veux imprimer en 2 couleurs voila ce qui ce passe:
    la première couche avec le fil 1 est ok puis il se rétracte de x mm pour laisser le place au fil 2, mais au moment de passer au 2 fil la le fil celui ci ne fait pas sont avance de x mm pour arriver a la buse
    il commence a sa position donc pas d écoulement en sortie de buse
    j utilise simplify3d version4 si vous avez un tuyau il sera bien venu
    merci d avance
