Repetier-Firmware configuration tool doesn't display the window where you can check the printing time and filament printed quantity, but when I upload the firmware at the arduino ide to the motherboard it displays this window at my full graphic smart controller lcd,strange!
Is there's any method to reset the "Printing time?"
I've tried so many times
uploaded firmware with different EEPROM MODE each time,
still can't get it work ...
I just found that "Filament printed" can be reset or set to any value I wanted,
by using Repetier-Host --> [Config] --> [Firmware EEPROM confirguration]
It would open a new window which allows me to change the settings ...
There the second line "Fliament printed [m]" <-- I can change it to 0. That's great!
But I can't find where to change or reset the "printing time" in this Firmware EEPROM settings window.
Tried to update Repetier-Firmware with EEPROM MODE changed <-- not working.
The "Printing time" remain the same on the LCD screen as home the page#4.
Is there any way to do this?
I just want to rest the "Printing time" back to 0.
Think you.
It's just right after the next line of the "Fliament printed [m]"
with different name "Printer active (s)" <-- I change to 0. And it works!!
Printing time is now shows "0 Days 0:00"
I am I'm curious, and really want to learn more ...
Is there some how I can do it by LCD menu?
Or is there a gcode command that I can use,
then everytime when the printer starting to print a new thing I can have them reset to 0, automaticly.
Thank you.
I knwe the idea is a total counter.
I just wanted to see how much time and how long the filament used each time printed something out.
And a thought that if I can set both of them to 0 everytime beging to print an object.
Then I should can know that the usage of the printing time and filament used.
^____^
