Volumetric E and used Filament
Hello,
Today I noticed a little bug with RH and Slic3r.
When volumetric E is enabled the Amount of Filament is wrong.
I confirmed this by checking the gcode.
In gcode near the end there is a line:
; filament used = 2293.1mm (5.5cm3)
But RH says:
Benötigtes Filament: 5299mm
Because I didn't knew which one was wrong i resliced it without volumetric E and the RH value changed to:
Benötigtes Filament: 2224mm
I'm using Slic3r v1.2.6
