Printer always ON on startup
I use Ramps1.4
Changing ENABLE_POWER_ON_STARTUP option doesn't matter
So, I made some changes in printer.cpp to always set to LOW PSON_PIN if ENABLE_POWER_ON_STARTUP == 0
#if defined(ENABLE_POWER_ON_STARTUP) && ENABLE_POWER_ON_STARTUP && (PS_ON_PIN>-1)
    SET_OUTPUT(PS_ON_PIN); //GND
    WRITE(PS_ON_PIN, (POWER_INVERTING ? HIGH : LOW));
    Printer::setPowerOn(true);
#else
#if defined(ENABLE_POWER_ON_STARTUP) && !ENABLE_POWER_ON_STARTUP && (PS_ON_PIN>-1)
    WRITE(PS_ON_PIN, (POWER_INVERTING ? LOW : HIGH));
    Printer::setPowerOn(false);
#else
#if PS_ON_PIN > -1
#else
#endif
#endif
#endif
Now it works fine!
  • Shouldn't inverting POWER_INVERTING do the same trick? At least with 1.0 which has this code:
    #else
    #if PS_ON_PIN > -1
    WRITE(PS_ON_PIN,(POWER_INVERTING ? LOW : HIGH));
    #else
    #endif
    #endif
  • I think it will work fine
    #if PS_ON_PIN > -1
    #else
    thanks, please add it to
    https://github.com/repetier/Repetier-Firmware/blob/master/src/ArduinoAVR/Repetier/Printer.cpp
    Maybe some combination of POWER_INVERTING and ENABLE_POWER_ON_STARTUP will do the same trick, but it is bad idea.
  • It's already in 1.0. We do not fix older versions.
