Mirror motor signals
I am having a hard time getting Mirror motor signals function to work I am using version 0.92.9 configuration tool. I am trying to mirror the Z axis to extruder 1. I have set Z axis to both Z axis and extruder 1 and both sockets work fine when configured as a stand alone socket. When I mirror the axis only Z axis socket works, even with the extruder 1 as the primary z axis socket, and the z axis socket as the mirrored. Any advise would be greatly appreciated.
Ramps 1.4, Mega 2560, DRV8825
To rule out any hardwrae problems you could also make extruder 0 use stepper E1 and E0 to mirror Z. Try also with motors not mounted to z axis to make sure it is not just friction preventing the move. If both Z parts are not parallel in height you can add so much friction a motor would not rotate.
