Repetier config for Kossel Mini (for Kossel Mini users only)
Hello all,
Iam new in 3D (probably read it one houndred times...)
and i have Kossel Mini  http://reprap.org/wiki/Kossel
sadly with original Marlin firmware configuration and I would like to update it with repetier.
Iam not very technical person and due to my poor english skills I have found problem to get thourg the repetier firmware configuration tool. In my marlin config. instead of values there are mathematical equations or completely missing definition.
exmpl.
#define Z_MAX_LENGTH (Z_MAX_POS - Z_MIN_POS)
delta_floor _safety_margin_mm is not there...
Long story short.
Can you pls someone send me working repetier config for Kossel Mini which I would use as a template?
