I have Tronxy P802ma (with Z probe) Ramps 1.4 + arduino mega.
My melzi board was failing. So i replace it by ramps 1.4+ arduino, but i have some problem for fix the Z prob, my print start more or less 10mm above the bed.
Anyone can share the configuration.h please ?
Benoit
The offset is set with z offset with lcd panel higher value closer to bed. Atleast with melzi marlin.
If its an fw problem mayby you can download an p802ma fw and just check with your fw and that to se wats difrent
Also if you have z min = z probe use dev version and not 0.92.
