after update glitches
Hello,
I found out that the slicer controls via repetier host wont work anymore after the update to repetierhost 2.0.
even if i set everythign right in slicer i still get a very weird print.
Greetings,
Jelle
  • Can you explain? I slice several times per day without any problems, so what is the error you get with which of the supported slicers?
  • i use slic3r, and the problem is that repetierhost wont overrule the slicer settings, i have overrule marked, but it doenst actually overrule.
  • Have just tested and worked fine. Different pattern, layer height and infill density was shown. Which parameter does not work? You should see the command line arguments with overrule values in the log and so you see they get send.
