Autolevel first point is off the bed
I have been trying to get my BLTouch setup on my Tronxy. I am able to control it appears to be working correctly, however, when I run G32 S2 as i have seen is the auto level command my first point after a X and Y home is off the bed. I can not seem to find the setting in the configuration.h file to account for the point. Any ideas?
I will try double checking what EEPROM has for cords but I have tried all 3 options for leveling, Each time it only moves 25 mm from X home and tries to probe which is off the bed.Any way to change the first position its going to? I have modified the #define Z_PROBE_X1 60 and no matter what its set to it does not move anymore than the 25mm.
**Edit** So some how I redownloaded and flashed and magically my first point is hitting.
What is the proper start GCODE for printing?
I allways heat the hot end to 195 so there is no hard plastic to press into the bed when the nozzle lowers to Z0 after it has homed Z.
