Output extruder
Dear all
I found some similar subjects but no of them really helped me...
On repetier host, the Output Extruder curve is always showing 0 even if 1 or 2 of my extruder are heating. Everything is find for the bed.
I can't found why, although the M105 response seem to be find but I can't found on the internet what is the good one.
Here is a screenshot of the situation: https://ibb.co/hQLg0k
Thanks for helping!
Pierrealexb
Thanks for helping!
Pierrealexb
You are right about the room temp, I needed to deassembly my hotend because of some other troubles, so the termistor is not stuck to the heater. But is become hot when I ask for, so the pin is good.
I have the same output problem with an other computer and an other printer. Could it be Repetier Host does'nt read the M105.
You can't see it on the picture but the bed output is find.
Any way, the output extruder problem is still present when the hot end is assembled, even with an other printer on an other computer. Could it be the order of the info of the M105 response wich is not good?
The problem appears with different version of marlin.
Thanks!
How can I change that in RH?
Thanks!
