Endstops not activating!
Hi, When I try homing the bed or x axis, it hits the endstop and keeps on going, any ideas on why this happens, I've checked the wiring and its all fine!
  • Test if firmware is configured correctly with M119 which shows endstop status. Test manually to see if it changes. For example if you home x to left you must have z min endstop triggering at that side.
    How can I configure this? Where abouts is it in the code?
  • i will show him i know the person
