BLtouch whit RADDS and repetier firmware
I've just connected up a BLtouch sensor to my RADDS controller. It works fine when I activate this with "M340 P0 s700". I have inserted the start script and stop script under z probing in firmware (configuration.h) But when I'll take a G28 is not activated. Anyone know what I need to do to get this to work?
I tried to check with M119 and if I use endstop (mechanical) it works; H when triggered and L when not triggered.
But then when the Bltouch is connected (on the same pin the same way) it just stay L all the time.
I tried to connected on ZMAX pin and it is the same thing not working...
