Mix: Both stepper motors turn at the same time
Hello, I've been trying to get a mixing extruder to working but everytime I set the firmware (92.3) to mixing extruder and test it in Repetier-host, both extruder turn at the same time, even when switching between extruder. I ran it as a dual extruder and it works fine but when I turn mix on in the firmware, both turn at same time. I've check the printer setting in Repetie-host to make sure it was set for mix too.
Any suggestions would be greatly appreciated.
ic2dcom
ic2dcom
The eeprom setting show 16 Extr 1 Weight with a value of 10. So do I change the first one (Extr 1 Weight 1 to 100 instead of 10 and then set the rest of the weights to 0. Is that correct?
There isn't a way set these weights up in the configuration.h yet?
Now I have to work on setting the retraction so I don't end up with back-flow again.
