Are my firmware settings wrong?
Hi forum,
When I try to use manual movement on repetier server my machine moves about 5mm whether I send a 1 or 10mm command. The manual movement does not seem to work on the 0.1, 50 or 100mm commands at all.
On another matter, while using the control knob on the machine itself, the Z stop registers 'on' on my LCD screen (RepRap Mendel mkIII) but stops movement only in the upward direction. Would reversing the Z axis on repetier server remedy this?
