conversion from old to new firmware using repetier firmware configuration tool using diamond hotend.
I bought a delta 3d printer kit with double extruder. The printer came with the repetier firmware. it was working fine but had a twisted prints. instead of fixing that print that I decided to go for the diamond hot end using the stepper expander. I ordered the stepper expander X2 and want to build the firmware using the configurature tool. is there any already made firmware for that?
So far I attached only two extruders and trying to use the configurature tool. I have two problems:
1. As soon as I switch on the heat using the repetier host, the error message is for the heater decoupling and switching all heaters off.
2. Z axis moves down very slowly for printer.
Please help
Him
