Da Vinci 1.0A E3d V6 Hotend - Nozzle height issues
I no longer have Z Probe.
I also installed an E3D V6 hotend. The Nozzle height changed from the stock nozzle and now When I try to use Manual Leveling w/paper method, the nozzle will start printing too high.
If I start a print and stop the machine and level the bed that way and start the machine and start the print again, it will print fine. But using Repetiers Manual Level option results in the nozzle being too high.
What must I change in the firmware if I no longer have a probe and want Manual Leveling to match up?
Thanks for any help.
Morning!
I am not sure if the Da Vinci has Z Max Homing. So if I shorten my Z Max Length it will bring the nozzle down? In my printer settings I have Endstop = off. Not sure if that means anything.
Thanks a bunch.
