Wiring a laser driver on GT2560
Hello to everyone,
I want to connect a laser driver to GT2560 motherboard. Does anyone have any experience with wiring (and settings in firmware)?
Laser driver has Vin and TTL in.
Until now I have connected only Vin to the second hotend (as it is free) but not working as I was expexted (more laser lines on start and end of gcode)
http://www.ebay.com/itm/332081247422?_trksid=p2060353.m2749.l2649&ssPageName=STRK:MEBIDX:IT
I have connect the laser to 2nd hotend terminal, but in firmware I have declare only one extruder. When I declare two extruders, laser dosnt work at all (flashes some times betwen movements).
what type of printer do you have?
@Repetier :
there is another guy also with a delta fighting with this issue see Post :
"Laser turned on on all moves".
i loaded configuration from this guy to dev version and checked on Mega/Ramps.
so it does not switch off laser during g0 moves .
no reaction to M5, laser gets switched on during any kind of move...
changing from delta to cartesian it works as it should.
Did crosstest on my due setup and in both versions(delta and cartesian)
Laser works as it should. might that be a memory problem on AVR Mega2560?
any idea?
What about this? " 100mm line long (x=0, y=0) in inkscape are been transformed to G1 X28.2222 Y0???"
