can't connect at the Baud rate i have set in config
I have the baud rate set at 240000 but when I go to connect I have to use 115200 or I can't connect
if I flash marlin it will connect at 240000.
any suggestions?
Gary
  • 240000 is not supported anywhere. You mean 250000 i guess.
    Repetier stores baud rate in eeprom, so connect with 115200 since that works go to eeprom editor and set baud rate to 250000 and reconnect with that speed.
  • sorry meant 250000 double checked and its set at 250000...
    gary
