Big problem
I have a Geeetech Rostock mini G2/G2s and seems it was working just fine and during the start up for another print, I noticed that on the bed the print layer out the filllement partly nice, none only smear and stringy, till it got to the 4th layer and started to do fine. So after that print, I turned the system off because I hat to leave. When I got home I was going to do another spring and started up every thing, loaded the project, the other half of the first one, and hit print. Now the careage started to move, only to have the Y axes move up. Hit stop, checked the settings and couldn't find any thing. shut down and re loaded Repetier-Host again and loaded a small simple project, and hit print again, same thing, only Y would go up, snd I stoped it. Now i'm thing its a firmware issue and I have no idea what firmware is with the Repetier-Host, and if there is how do I find it and if not how do I go and find the firmware to down load for my printer. I'm new at this and beating my head trying to figure this out. HELP
