Motors lurching
I just hooked up my Rambo 1.3 board and downloaded my firmware onto it. The printer configuration is a delta. When we try to move the head only one motor will move. The other two seem to just lurch forward and then backward. When we unplug the motor that works and plug it into the one of the steppers that werent working they start to work. Any advice on how to fix this issue or where it might be occuring at?
as you say :
it seems Drivers are ok. so may be Connection from Motor to connector is loose.
(can be in loose in connector as connector contacts are crimped).
or also might be Motor cable are not in correct order (check Colors in connector)
so i guess your Motors have 4 wires , check the coils with Ohmmeter.
usally red/blue and green/ black are on Motor , so you should make one measurement
between red and blue and also one measurement between green and black wire.
readings should be the same
set to (65,65,65,65,65)
