Auto bed level "working", software compensation not so much...
I have a i3 clone with melzi board and updated to repetier 0.92.9 with 3 point auto bed level enabled. Everything seems to work fine:
Bed gets probed at 3 points at roughly X0,Y0, X0,YMax and XMax YMax and probe readings are repeatably consistent with G32 in start gcode of the print.
Also Z axis is moving up and down as if the software correction is doing its thing.
The problem is, that the first layers are not applied evenly across the surface, on the left side of the bed everything is fine, while on the right side the nozzle is too close to the bed by maybe 0.1 or 0.2mm and the extruder starts to slip on the filament since it cannot push it through the nozzle.
Any idea why this is happening?
Regards,
Murch
