LCD module to make it compatible with RAMPS1.4 board
Hello, I had this LCD module: https://www.aliexpress.com/item/LCD-2004-Display-Module-Smart-20-4-Controller-with-Adapter-for-3D-Printer-Ramps-1-4/32223817300.html?spm=2114.13010608.0.0.JwYLps but from the item's description, Ramps1.4 board is not listed there but I tried to use it to my Ramps board but what I have is a blank flickering screen. I wonder if I can edit the pins to make it compatible with Ramps1.4 but I have no idea where to start. I also tried different types of LCD option from the configuration file of Repetier Firmware but I have no success, so I'm thinking that maybe this board is only compatible with GT2560 and Rumba board but I still want to try if this will also work with Ramps1.4 board, maybe the orientation of pins is just different so I hope I can get a solution from you guys. Thank you so much...
