Random pausing during print
I suddenly started experiencing random pauses during a print. Was using an older version of Repertier server on a Pi 3. Version 7.something I think.
Was originally installed around march this year and was working fine until a few days ago. Seamed to happen shortly after my webcam feature disappeared.
Iv tried updating to the latest version, and it still happens.
If I plug the printer into my laptop and print from there it is okay, so must be the Pi or Repetier server that is causing the problems.
Any suggestions how to diagnose and fix the problem?
I tried the new pre-configured Pi SD image but couldn't get it to connect to my WiFi. Sounds like a common problem so I just went back to my original SD image and updated.
Any help would be greatly appreciated.
Does that mean that i need to set the input buffer size in the raptier to 16 as well?
I am connecting to it via an ESP3D via direct pin connectioon.
- Changing the original USB cable (~1.5m long) for a shorter (~50cm long) and thicker. Now I have no more warnings in the logs, and no more random stops of the printhead.
Hoping this can help someone else.
