Random pausing during print
I suddenly started experiencing random pauses during a print. Was using an older version  of Repertier server on a Pi 3. Version 7.something I think.
Was originally installed around march this year and was working fine until a few days ago. Seamed to happen shortly after my webcam feature disappeared.
Iv tried updating to the latest version, and it still happens.
If I plug the printer into my laptop and print from there it is okay, so must be the Pi or Repetier server that is causing the problems.
Any suggestions how to diagnose and fix the problem?
I tried the new pre-configured Pi SD image but couldn't get it to connect to my WiFi. Sounds like a common problem so I just went back to my original SD image and updated.
Any help would be greatly appreciated.
  • Yes, wifi is a bit broken in V5 and will be fixed with new update.
    To diagnose it you would need to log a print and check at times when it happens. Typical I'd expect some communication errors when print pauses. For this some solutions depending on used firmware exist to solve them more quickly.
  • Just run a couple of prints, both had just one noticeable pause in them.
    I searched logs for error and wait and these two popped up.
    Not quite sure what to make of these. Any sugestions?
    > 15:03:54.182: ok 33318
    < 15:03:54.182: N33324 G1 X89.891 Y93.537 E4.52311
    > 15:03:54.211: ok 33319
    < 15:03:54.211: N33325 G1 X89.250 Y93.596 E4.55964
    > 15:03:54.228: ok 33320
    > 15:03:55.587: ok 33321
    > 15:03:55.587: ok 33322
    > 15:03:55.587: ok 33323
    > 15:03:55.588: ok 33324
    > 15:03:55.588: ok 33325
    > 15:03:55.588: wait
    < 15:03:55.588: N33326 M105
    < 15:03:55.589: N33327 G1 X88.626 Y93.541 E4.59523
    < 15:03:55.589: N33328 G1 X88.020 Y93.379 E4.63082
    < 15:03:55.589: N33329 G1 X87.452 Y93.114 E4.66642
    < 15:03:55.589: N33330 G1 X86.939 Y92.755 E4.70201
    < 15:03:55.590: N33331 G1 X86.596 Y92.412 E4.72955
    < 15:03:55.590: N33332 G1 X85.777 Y92.192 E4.77766
    < 14:15:54.626: N479 G1 E3.00000 F4200.00000
    > 14:15:54.806: ok 473
    < 14:15:54.806: N480 G1 X127.679 Y101.692 E3.28549 F1200.000
    > 14:15:54.919: ok 474
    < 14:15:54.920: N481 M105
    > 14:15:57.174: ok 475
    > 14:15:57.175: ok 476
    > 14:15:57.175: ok 477
    > 14:15:57.175: ok 478
    > 14:15:57.175: ok 479
    > 14:15:57.176: ok 480
    > 14:15:57.176: ok 481
    > 14:15:57.176: T:195.69 /195 B:50.15 /50 B@:0 @:81
    > 14:15:57.176: wait
    < 14:15:57.177: N482 M105
    < 14:15:57.177: N483 G1 X125.074 Y101.334 E3.43477
    < 14:15:57.177: N484 G1 X124.616 Y101.181 E3.46222
  • Checked my firmware settings (Repeteir firmware by the way), and I have the "Send "wait" when firmware is idle." option enabled.
    Ill run a print from my laptop and see if i get the same "wait" commands.
  • Ran a 90 minute print from my laptop and no "Wait" in the log.
    Definitely the Pi or Reptier server that is causing the problem.
    Everything on the Pi is upto date. Ran the apt-get and apt-upgrade commands last night.
    Andy sugestions?
  • These 2 waits are no pause and are complete in accordance with the protocols. You see firmware is firing a row of ok followed by wait. So server had buffer full and correctly did not send new commands as "ok" was missing and as soon as it received "ok" it answered with moves. This can happen when a longer move prevents freing next "ok".
    If exactly that time correlates with a pause it might be that server was paused by linux for some time intensive other job. But that is more or less impossible to detect afterwards. From 0.80.3 on it will therefore get a higher priority.
  • Iv not checked the exact times of the pauses, but I noticed two pause and there are two waits which seams to much of a coincident.
    I checked the niceness parameter for repetier server using the top command and its at the minimum of -20 which as far as i know means the highest priority already.
    There are a bunch of other command with nice = -20, but i don't know enough about software to know if this is normal or not, and if not what to do about them.
    The command constantly at the top of list when im not printing, and using 1.6% cpu is mjpg streamer. Is this worth killing and trying a print without?
  • 1.7% is nothing if you have 400% on pi 3, so that should not be the issue.
    As you already have nice -20 you are using wheezy I guess. On Jessie it gets ignored with current release since I need to reduce limit before it works.
    Other processes with -20 should be kernel processes also needing high priority.
    Maybe run top on ssh console while printing to see what takes high cpu when hang happens, but would require fast reaction if it is just a short running process like a cron job doing some regular tasks like cleaning logs. As I said log show a possible delay in communication but also show server reacts immediatly after it gets the data. So is it a long move that delays because it blocks the input or is there a hang on communication for some unknown reason.
  • Hellow. Is there any update on the issue? im having the same problems as described here. Latest server version running it on a raspbery pi w zero on base install.
  • There is no general problem causing pauses. You need to check console if you experience communication errors which can cause this of course. Also make sure to not have too small gcode segments. With ping pong mode disabled you can normally send 300 lines per second without problems. If your model is so fine that it exceeds it the printer will also get problems getting to speed.
  • In marlin i have
    #define BLOCK_BUFFER_SIZE 16
    Does that mean that i need to set the input buffer size in the raptier to 16 as well?
    I am connecting to it via an ESP3D via direct pin connectioon.
  • No, that is just how many moves marlin caches. The input buffer is most likely 127 byte long.
  • ESP3D - does that mean you use tcp/ip over wifi for communication? In that case you might get pauses if wifi gets interrupted. I'm not a big fan of using wifi for sending serial data as it is not stable enough especially if I look at my wifi network. Leases, other devices connecting, delays due to big data packets getting send. No idea what will happen there all the time.
