Velocity Painting makes volumetric flow rate super high
in Bug Reports
I've been trying to use the velocity painting tool. I can slice the object just fine and when I inspect it via prusaslicer g-code viewer, the volumetric flow rate shows to be around 3.836. However, when I create the velocity painting, my volumetric flow rate shoots up to around 1410.782. Everything looks fine, just the volumetric flow rate is causing issues. I've checked my slicer and it's showing the correct parameters, I've tried limiting the flow rate and volumetric flow rate in the slicer, and can't find anything in Repetier to change it. Any ideas what's causing the volumetric flow rate to fly through the roof when using velocity painting?
