file size limits
I am trying to find if there is a maximum file size that repetier host can handle
  • I keep getting out of memory errors
  • No hardcoded limit, but especially gcode viewing needs a lot of ram and video memory, so complex models might exceed your memory. It also depends on the quality for preview you defined. The ugly simple line needs the least memory and the better the quality gets the more ram you need. So try reducing that first.
