WEBCAM INSTALL IN WINDOWS 10 REPETIER SERVER
I have my Repetier Server Pro version installed on a Windows 10 machine. The printer works very well but I am unable to install a Logitech C290 WebCam. I have followed the instructions on using Yawcam and put the addresses in as described. I can see the images on the Yawcam app but not in Repetier.
http://192.168.1.104/8081/video.mjpg
http://192.168.1.104/8888/out.jpg
Did you try deactivating your firewall to see if firewall is blocking the stream? In W10 default firewall asked me if I wanted to allow it, but there are many firewalls with different behaviour. So best is deactivate, test and if it works find the correct setting to allow yawcam to publish the streams.
Is there some way I can upload a screen image of my setting to you? I am doing something wrong but cannot find it in my settings
Also I just saw that your ports are wrong declared. It is <IP>:<Port> not <IP>/<Port>
so your links should be:
http://192.168.1.104:8081/video.mjpg
http://192.168.1.104:8888/out.jpg
I knew I was making some dumb mistake; I just could not see it.
It works perfectly now,
Many thanks,
