Migrating Repetier Server to another Raspberry pi
Hello, I have repetier server set up on an old raspberry pi. Ive recently got a new pi 4 which has a lot more power.
I dont want to loose all my settings and configs etc from my current install. Is there a way I can migrate repetier server to my new raspberry pi?
I've heard I cant just insert the old SD card since the PI 4 architecture is slightly different.
Otherwise you need to copy contents of /var/lib/Repetier-Server to new image. Easiest way is to use Repetier-Server Monitor to make a backup of old sd card and restore on new sd card. Backup/Restore is the only function also working for free versions so ignore any license required messages if you use free version. If you use pro version deactivate license before overwriting sd card.
