The speed, acceleration and dimensions of the print area are not recorded in EPROM
The problem is the following: change in the firmware of variables
#define X_MAX_LENGTH 105
#define Y_MAX_LENGTH 150
#define Z_MAX_LENGTH 30
#define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_X 100
#define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_Y 100
And others in charge of movement
do not affect the operation of the device. Given that the values that I entered using the alternative firmware before are clearly stored in the printer's memory.
At the same time, some variables work, for example, from the section // ################ Endstop configuration #####################
Tell me what you need to do to save these settings in EEPROM?
EEPROM_MODE = 1
(#define EEPROM_MODE 1)
M502
M500
to reset eeprom to config values.
