Where is the "wall thickness" setting in CuraEngine?
I'm trying to configurate my printer. And I'm trying to get the flow rate correctly before going further to calibrate the X/Y/Z stepper motors.
I'm using a 0.4mm nozzle and I would like to set my wall thickness and make a single wall testprint to measure and adjust the flowrate. But I can't find the wall thickness settings in the CuraEngine settings. Or am I overlooking something?
I'm using the latest 2.2.3 version of Repetier Host.
I overlooked this because I thought this section was all about the infill parameters. So the infill lines.
But when put it to 0.8 I see it actually calculates 2 outer shell lines
So when I put the shell thickness here to 0.4 then I may asume that it prints a single shell at the nozzle diameter of 0.4mm?
So when I put in 0.48 it should print a single wall at 120% of the nozzle diameter?
