How to set up Diamond triple-filament single-nozzle mixing extruder on Rumba board
Hi, I have very recently set up a Diamond hotend and had to grudgingly switch to Marlin firmware after failing to get Repetier firmware v0.92.3 to work.
I used the Repetier firmware config portal to enable Mixing Extruder and added two more extruder motors. When I use the firmware, no matter which extruder I attempt to drive (T0, T1, T2) it results in all three extruders rotating at the same time, with three times the distance as they normally should given the command. Is this sort of setup supported?
Is an extruder such as the Diamond supported in Repetier? Links to the Diamond wiki, and to my config files, are below.
http://www.reprap.org/wiki/Diamond_Hotend
http://www.neveroddoreven.com/temp/Marlin_Configuration.h.txt
http://www.neveroddoreven.com/temp/Marlin_Configuration_adv.h.txt
http://www.neveroddoreven.com/temp/Marlin_pins.h.txt
http://www.neveroddoreven.com/temp/Repetier_Configuration.h.txt
http://www.neveroddoreven.com/temp/Repetier_pins.h.txt
