Update Problem von 1.1.0 auf 1.1.2
Automatisches update startet , wird aber nicht beendet . Nicht nach 5 min und auch nicht nach 6 Stunden.
10 versuche mit neustart schon probiert über zwei Tage.
Was kann man noch tun?
Damit scheint es problemlos zu klappen.
Newer pi images also have a command
installLatestServer
to install latest version manually.
Otherwise paste this (same as installscript) into ssh console:
cat /proc/cpuinfo | grep ARMv6
IS_V6=$?
cd /home/pi
rm RepetierServerLatest.deb
if [ "$IS_V6" == "0" ] ; then
echo "Raspberry Zero or 1 detected, installing armel version..."
wget http://download.repetier.com/files/server/debian-armel/RepetierServerLatest.deb
else
echo "Raspberry with v7 or newer command set found. Installing armhf version..."
wget http://download.repetier.com/files/server/debian-armhf/RepetierServerLatest.deb
fi
sudo dpkg -i RepetierServerLatest.deb
That's not comprensibile and it's not comprensibile for a paid software.
You should make a procedure to do the update if it don't work automatically (as should do).
I have a raspberry pi with repetier server 1.1.0.
Tried to update automatically (as i do since today), but nothing: stuck for 40 mins.
Then, tried via ssh as wrote in update changelog (but that says for Linux), and nothing: command not found.
So now, how to update it?! Do i have to download latest pi image, transfer to the server and sending some ssh code?!
EXPLAIN US, please.
Which solution did not work and what was the error message in ssh? With changelog method and above 2 solutions there are 3 ways. You can also add the official solution to add it manually which also works. That makes 4 possible alternatives.
Einfach mit Putty oder Windows powerShell anmelden.
Windows PowerShell starten und folgende befehle eingeben.
ssh 192.xxx.xxx.xx (IP vom eigenem Repetier-Server)
(password): xxxxx
sudo /usr/local/Repetier-Server/bin/RepetierInstaller /usr/local/Repetier-Server/etc/RepetierServer.xml
Fertig
