Lose all GCODE temperature information
Hey folks,
I've been scratching my head for a few days now. I could be doing something wrong, but this seems to be a bug.
Version: 2.2.2
Printer: Geeetech A10M
Self Leveling
Issue. The original GCode that comes with the software looks like this.
Version: 2.2.2
Self Leveling
; Default start code
G28 ; Home extruder
G1 Z15 F{Z_TRAVEL_SPEED}
M107 ; Turn off fan
G90 ; Absolute positioning
M82 ; Extruder in absolute mode
{IF_BED}M190 S{BED}
; Activate all used extruder
{IF_EXT0}M104 T0 S{TEMP0}
G92 E0 ; Reset extruder position
; Wait for all used extruders to reach temperature
{IF_EXT0}M109 T0 S{TEMP0}
When I test this, it works fine. Everything is exported to the gcode file as it should be. I didn't copy paste it, because I already lost it. However, when I add this line:
G28 ; Home extruder
G29 ; Level Bed <<<<<------------------ This line
M107 ; Turn off fan
{IF_BED}M190 S{BED}
Then everything goes crazy. My actual exported gcode file now looks like this.
;Generated with Cura_SteamEngine 15.01
G28 ; Home extruder
G1 Z15 F100
M107 ; Turn off fan
M190 S50
;Layer count: 87
;LAYER:0
M106 S127
G0 F9000 X86.059 Y88.201 Z2.800
;TYPE:SKIRT
G1 F600 X137.283 Y88.201 E24.32908
G1 X137.283 Y139.425 E48.65816
G1 X114.283 Y139.425 E59.58212
There is no command for extruder temperature, and there is no code for what extruder to use (T0 or T1). And there is nothing I can do about it. I can uninstall and reinstall the program, and it will start working again. But as soon as I add that G29 line just a single time, then everything goes crazy on me and will not output temperature or extruder code.
Am I missing something simple?
Thanks,
Mac
Thanks,
Mac
In your non working result G29 is also missing, so you either did not safe the new profile or on the right tab you have selected a different profile then the one you edited. Would be the only explaination that makes sense to me knowing that it can work.
It's a brand new install and only has a single profile, and even after removing the G29 line it doesn't export the hot-end temperature or extruder information.
I've duplicated the results on a second computer. I'll do it all again this evening with a new install and add some comments in the profile code. I'll try to show it more explicitly, but this does appear to be a legitimate bug.
Thank you for the help. Let me know if there is anything else I can try to either confirm the bug, or find what setting is wrong.
Mac
Aha! Now I feel really dumb. I probably should have mentioned this is a dual color printer. I have two extruder motors, but only a single nozzle/mixing extruder. I should have recognized what was happening with the g-code "if" statement, but I'm not savvy enough with it (yet). So yes, that was the main issue. I was slicing on the second extruder (T1) but the code only looked for the first (T0).
I changed the start g-code to this. I don't know if this is the best way to do it:
I'm not sure why Repetier doesn't automatically account for this. My printer was set for two extruders and a mixing nozzle. It may be something to account for in a future update.
However, I am still confused by something. Just for the fun of it, I loaded a multi color lizard from Thingiverse. I did a couple things just to see how it works out in the g-code.
- First, I set a Skirt to print. In the settings, I say the support extruder is Extruder 2, so the skirt should be printed with T1.
- The body of the lizard is also extruder 2. So it should print with T1.
- The eyes are a different color and extruder 1. So it should print with T0.
I would attach the g-code for this, but I don't see a way to do it. It starts like this:There is nothing in this code that tells it to start at T1. Shouldn't it start there, since the support material is set for the second extruder? It heats T0, which makes sense as it is a mixing extruder. But I don't see anything to indicate which extruder to start with. In fact, when I search for T1, I don't find it until line 1,085, where it now says ;TYPE:SUPPORT. If support is just starting now, what was it printing before? I haven't actually tried this print, so it probably works fine. But I'm curious how this works.
Thanks to you both for all the help.
Mac
SOLVED
I'm using two computers. The one I posted gcode from above looks like it would have worked successfully, at least for the temperatures. This computer runs my printer, and it looks like here this issue goes over to the heated bed as well. I loaded an xyz test cube to see if I could get a successful print going. This is my start g-code:
Take a look at my filament settings. I snapped an image and have the exported g-code on the side. You'll see I'm using the correct profile names.
https://ibb.co/gW1ZcnW
For some reason, this is exporting with a 50° temp instead of 55°, as in my settings. It looks like that was happening in my first post as well. I just hadn't noticed it.
This is my printer extruder setting. So it isn't a maximum temperature issue.
https://ibb.co/PtcKMdz
Weird...
Let me first say, I love Repetier Host. This program has always worked great for me. But...it doesn't do well for two extruders and a mixing nozzle. I sliced the test cube on extruder 2 (T1) and printed. It didn't work. It printed with the first extruder. Not surprising, because there is nothing in the g-code that tells my printer to use the second extruder.
There is a workaround, I just had to add T1 into the start g-code, but then I have to remember to use the right profile setting. This seems like another upgrade that Repetier could make. It is just one line based on what extruder you choose for your part.
You are not the first mentioning the settings are not being used, but I can never replay the problem. So I still think these users do something wrong and I can not say what. Importent fact is left configs must be saved so the changes are used. Also selecting them on the left side does not use them - you need to select the profile on the right side in the dropdown box. Actually normally left side is never opened once you found your settings.
