Raspberry Pi Image Bild kann nicht gedreht werden.
Hallo, ich habe seit Stunden das Problem das ich das Bild von meinem Raspberry Pi B 4 GB nicht gedreht bekomme verwendet wird das Raspberry Pi 7" Touchscreen Display. Habe schon im Internet vergebens gesucht ob jemand das gleiche Problem hat, Leider bin ich wohl der Nur mit dem Problem.
Config.txt:
# For more options and information see
# Some settings may impact device functionality. See link above for details
# Allow higher load on usb
max_usb_current=1
disable_splash=1
# Flips the display using the LCD's inbuilt flip functionality. Rotation: 0 = normal, 1 = 90°, 2 = 180°, 3 = 270°
# lcd_rotate=2
# Rotate in gpu instead. 90 and 270° require extra memory!
# display_hdmi_rotate=0
# For legacy drivers, same as display_hdmi_rotate
# display_lcd_rotate=2
# Deprecated, for backward compatibility
enable_uart=1
dtoverlay=pi3-miniuart-bt
# uncomment if you get no picture on HDMI for a default "safe" mode
#hdmi_safe=1
# uncomment this if your display has a black border of unused pixels visible
# and your display can output without overscan
#disable_overscan=1
# uncomment the following to adjust overscan. Use positive numbers if console
# goes off screen, and negative if there is too much border
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
# uncomment to force a console size. By default it will be display's size minus
# overscan.
#framebuffer_width=1280
#framebuffer_height=720
# uncomment if hdmi display is not detected and composite is being output
#hdmi_force_hotplug=1
# uncomment to force a specific HDMI mode (this will force VGA)
#hdmi_group=1
#hdmi_mode=1
# uncomment to force a HDMI mode rather than DVI. This can make audio work in
# DMT (computer monitor) modes
#hdmi_drive=2
# uncomment to increase signal to HDMI, if you have interference, blanking, or
# no display
#config_hdmi_boost=4
# uncomment for composite PAL
#sdtv_mode=2
#uncomment to overclock the arm. 700 MHz is the default.
#arm_freq=800
# Uncomment some or all of these to enable the optional hardware interfaces
#dtparam=i2c_arm=on
#dtparam=i2s=on
#dtparam=spi=on
# Uncomment this to enable infrared communication.
#dtoverlay=gpio-ir,gpio_pin=17
#dtoverlay=gpio-ir-tx,gpio_pin=18
# Additional overlays and parameters are documented /boot/overlays/README
# Enable audio (loads snd_bcm2835)
dtparam=audio=on
[pi0]
# Uncomment for network over usb
# Has sideeffects on usb bandwidth so webcams or usb sticks might get problems
#dtoverlay=dwc2
# Also add at end of cmdline.txt this:  modules-load=dwc2,g_ether
[pi4]
# Enable DRM VC4 V3D driver on top of the dispmanx display stack
dtoverlay=vc4-fkms-v3d
max_framebuffers=2
[all]
#dtoverlay=vc4-fkms-v3d
start_x=1
gpu_mem=128
Habe schon versucht mit # Rotate screen 180°
Leider alles vergebens.
  • Ich glaube bei dem display wäre
    lcd_rotate=2
    die Lösung. Wichtig - das # am Zeilenanfang schaltet die Option aus. Etwas dahinter zu ändern ändert nicht. Du must bei einer der Rotationsoptionen das Kommentarzeichen entfernen und den parameter setzen.
  • Super es musste nur # entfernt werden.
    Danke Schön <span>:)
