X And Y dimension ?
Hello All :
I have a question below .
Motor step angle :1.8
Belt pitch (in mm) =2mm (GT2)
Pulley tooth count =16
Steps per millimeter =100
when I move the X=50mm , I got real dimension is 30mm , What wrong with my Delta . how to correct my delta printer . change DELTA_DIAGONAL_ROD or some parameters .
thanks .
Hi :
I have clear eeprom settings then re-upload firmware , use G code G1 X50 Y0 Z0 , it is still move 30mm by hand measurement . Can any way to correct this . May i change DELTA_DIAGONAL_ROD more or less .
Thanks .
