Nozzel to far from the bed
edited July 2015 in General
I'm trying to set up Z probing on my felix 3.0
I all seems to work beside that the nozzle is to far from the bed.
No mater what i try i won't get any closer
i use also use the probe as a z min end stop
this is my config file
#define ENDSTOP_X_BACK_MOVE 5
#define ENDSTOP_Y_BACK_MOVE 5
#define ENDSTOP_Z_BACK_MOVE 1
#define ENDSTOP_X_RETEST_REDUCTION_FACTOR 2
#define ENDSTOP_Y_RETEST_REDUCTION_FACTOR 2
#define ENDSTOP_Z_RETEST_REDUCTION_FACTOR 2
#define ENDSTOP_X_BACK_ON_HOME 0.1
#define ENDSTOP_Y_BACK_ON_HOME 0.1
#define FEATURE_Z_PROBE 1
#define Z_PROBE_PULLUP 1
#define Z_PROBE_ON_HIGH 1
#define Z_PROBE_X_OFFSET 0
#define Z_PROBE_Y_OFFSET 0
#define Z_PROBE_SPEED 1
#define Z_PROBE_XY_SPEED 100
#define Z_PROBE_REPETITIONS 3
#define Z_PROBE_HEIGHT 1
#define Z_PROBE_START_SCRIPT "m502"
#define FEATURE_AUTOLEVEL 1
#define Z_PROBE_X1 0
#define Z_PROBE_Y1 0
#define Z_PROBE_X2 180
#define Z_PROBE_Y2 80
#define Z_PROBE_X3 0
#define Z_PROBE_Y3 150
#define FEATURE_AXISCOMP 0
#define AXISCOMP_TANXY 0
#define AXISCOMP_TANYZ 0
#define AXISCOMP_TANXZ 0
  • edited July 2015
  • #define Z_PROBE_HEIGHT 1
    means when it triggers the nozzle is 1mm from bed away. Should be 0 or slightly negative value to compensate bending and switch distance. Remember it is in eeprom as well, so you need to change it there.
  • When i disable the MIN_HARDWARE_ENDSTOP_Z  i can get the nozzle closer but not when i enable it
    If I a but a negative value for the height only 1 point gets measured before printing starts
  • A z probe is no endtop. Both are handled differently. In some special cases you can handle it as zmin but it is never ideal. z min stopps when triggered and that is z=0. That is the definition of a endstop. You can go up a bit from triggering point also that would mean nozzle was below bed.
    I'm a bit puzzled here. You have the trigger in the nozzle right? So you heat up nozzle and the do homing and that should trigger only when you hit bed + trigger distance. Then you go ENDSTOP_Z_BACK_ON_HOME mm up again to stop at 0. So ENDSTOP_Z_BACK_ON_HOME must be too high or you are
    using a cold nozzle and the old plasic causes a trigger to early. That is why 0.92 has now a new homing order Z up xy preheat Z
    to overcome that problem. Hope you use it.
