Exruder motor just stops
Hello everybody,
my extruder motor just stops turning after a 2-3 minutes. The printer doesn't output any error message on the terminal. The stepstick and motor stay cool (25 - 30 degrees I'd say). The stepsticks are cooled with a fan btw. When I reset the printer, the extruder motor immediately works again.
I already tried replacing the motor cables with new ones twice. I also replaced the extruder motor and tried a different TMC2208 of which I am sure that it works.
I even switched from Arduino Mega + Ramps to Arduino Due + RADDS 1.4. This did also not help (but I am staying with Due + RADDS now).
I don't know what else to try. With no error message, you'd think it can't be something in the firmware. But maybe someone knows something I don't.
Here is a pastebin of my configuration.h:
https://pastebin.com/8HAB024x
TMC2208 support is not in V1, only in V2 firmware. But problem is I think that it is the serial version and you need a serial per chip. But since your drivers work at start I do not really think that is the reason.
