Not seeing preview during print
Hi all, I have a DaVinci 1.0 that has had its firmware replaced with Repetier (1.0 or thereabouts). It is printing fine, but I want to see the animation of the extruder during the print. In the Manual Control screen, I only see part of one layer.
"Disable Quality Reduction" under "Behavior" is turned off
What am I missing?
What am I missing?
Correct. You should also know that quality reduction gets activated to protect print if framerate and hence communication speed drops down to much. If it drops too low and oyu want it on you should use Repetier-Server as print server instead of direct connection. That way frame rate does not affect quality.
